Add non-newtonian transport model on twoPhaseEulerFoam |
May 15, 2023, 10:15 |
riccardo
Rep Power: 3 |
Hi!
I was wondering if it is possible to add a non-newtonian model for the twoPhaseEulerFoam solver (compressible solver, with thermo effect). If it is possible are there some tutorial to follow? It seems that because of the compressibility and the thermophysical effect the way of doing it it is different from interFoam, for which it seems more straightforward. Thanks for the help |
June 11, 2023, 21:46 |
#2 | |
Mohammad Shakil Ahmmed
Rep Power: 15 |
Yes, it's possible to add a non-Newtonian transport model in the twoPhaseEulerFoam. Two-ways you may do that (depending on your rheology model only strain-rate dependent, or both strain-rate and concentration-dependent)- (1) You may edit the thermophysical model library to add the viscosity model, or (2) In the solver level, pass your mu calculation and replace the existing thermo-based mu calculation. Cheers |
cfd - post, help me, non-newtonian, tutorial, twophaseeulerfoam |
How to add Body force to a simple propeller model | hirota | OpenFOAM Programming & Development | 0 | September 2, 2021 04:49 |
How to add Body force to a simple propeller model | hirota | OpenFOAM Running, Solving & CFD | 0 | September 2, 2021 04:46 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
the difference of species transport and non-premixed combustion model | Messi | FLUENT | 0 | June 30, 2014 04:30 |
