OpenFoam Library compilation error
Old   April 9, 2023, 11:41
Default OpenFoam Library compilation error
Jaymeen Patel
jaymeen721 is on a distinguished road
Hello I am new to openFoam and using OF V 9, and I am customizing phaseChangeModel library to add specific Heat C and thermal conductivity.
I am added them under library incompressibleTwoPhaseMixture, code snippet is added in image, while compiling, I am getting an error: ‘const class Foam::immiscibleIncompressibleTwoPhaseMixture’ has no member named ‘C1’,
for incompressibleTwoPhaseMixture.H,
const dimensionedScalar& C1() const
return C1_;
//- Return const-access to phase2 Specific Heat
const dimensionedScalar& C2() const
return C2_;
//- Return const-access to phase1 thermal condcutivity
const dimensionedScalar& K1() const
return K1_;
//- Return const-access to phase2 thermal conductivity
const dimensionedScalar& K2() const
return K2_;
2nd for incompressibleTwoPhaseMixture.C
rho1_("rho", dimDensity, nuModel1_->viscosityProperties()),
rho2_("rho", dimDensity, nuModel2_->viscosityProperties()),
C1_(nuModel1_->viscosityProperties().lookup("C")),
C2_(nuModel2_->viscosityProperties().lookup("C")),
K1_(nuModel1_->viscosityProperties().lookup("K")),
K2_(nuModel2_->viscosityProperties().lookup("K")),
Error:
241 | volScalarField rhoCp = mixture_.rho1()*mixture_.C1()*mixture_.alpha1() + mixture_.rho2()*mixture_.C2()*(1.0-mixture_.alpha1());
phaseChange/phaseChangeModel/phaseChangeModel.C:241:102: error: ‘const class Foam::immiscibleIncompressibleTwoPhaseMixture’ has no member named ‘C2’
241 | Cp = mixture_.rho1()*mixture_.C1()*mixture_.alpha1() + mixture_.rho2()*mixture_.C2()*(1.0-mixture_.alpha1());
make: *** [/opt/openfoam9/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/phaseChange/phaseChangeModel/phaseChangeModel.o] Error 1
I am unable to figure out, where i am doing mistake, plz help.
Thanks in advance
jaymeen721 is offline   Reply With Quote
custom library, openfoam 9
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
