Difference between alphat and mut
Old   April 7, 2023, 12:22
Default Difference between alphat and mut
Felipe Silva Maffei
Maffei is on a distinguished road
Hello everyone!
I am programming a solver where I need to reload the compressible turbulent field. I can successfully realize the reading, however, the values diverge when I compare the turbulent read variables (mut and alphat) and the one calculated with the read turbulence field (let's say k and omega). I am sure about the code for calculating the variable mut because I get it from the turbulence model code (just rewrite it In my solver). I can't say the same to alphat but I am using (mut+mu)/Prandtl. Also I have changed the time write to binary with a precision of 30 cases.
The same happens when I create the turbulence object with:
Info<< "Creating turbulence model\n" << endl;
autoPtr<compressible::turbulenceModel> turbulence
    compressible::turbulenceModel::New
        rho,
        U,
        phi,
        thermo
and made the comparison using turbulence->aphat() and turbulence->mut() after run the turbulence->correct().
For what I programming, I really need to be able to compute the mut and alphat from the turbulent field and be consistent with the calculated primitive field.
Why am I having these diverging values?
Maffei is offline   Reply With Quote
error adding void fraction into the solver & Error when chemistry is on cmigueis OpenFOAM Programming & Development 23 August 14, 2016 15:53
mut and alphat & compressible flow sasanghomi OpenFOAM 2 September 17, 2013 15:42
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 23:36
XiFoam floating point error..mut error? achinta OpenFOAM 8 July 31, 2012 05:48
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 03:31
