Parallel: FOAM FATAL IO ERROR: compound has already been transferred from token
Old   March 25, 2023, 02:05
Default Parallel: FOAM FATAL IO ERROR: compound has already been transferred from token
Xiangjie Wang
XJ_Wang is on a distinguished road
Hi foamers:
I developed an inlet boundary condition for velocity, but can not run it in parallel.
In 0/U, I defined my inlet as:
inlet
         type            DSRFGVelocity;
         M              600;
         N              100;
        uref            22.5091;
        alpha           0.1538;
        zref            1.3860;
        inflowPar       pkqomega;
        value           uniform (0 0 0);
Then with a good mesh, I run:
decomposePar
mpirun -np xx renumberMesh -overwrite -parallel
It shows the error message:
[1] --> FOAM FATAL IO ERROR:
[1] compound has already been transferred from token
    on line 33 the empty compound of type List<vector>
[1]
[1] file: /ddnA/work/xxxx/DSRFGinflow/processor1/0/U.boundaryField.inlet.value at line 33.
[1]
[1]     From function Foam::token::compound& Foam::token::transferCompoundToken(const Foam::Istream&)
[1]     in file lnInclude/token.C at line 99.
[1]
FOAM parallel run aborting
Then I go to the file in processor1/0/U,
It is:
 inlet
        type            DSRFGVelocity;
        M               600;
        N               100;
        zref            1.386;
        alpha           0.1538;
        uref            22.5091;
        inflowPar       pkqomega;
        value           nonuniform List<vector>   // this is line 33
1086
(29.289282 3.8500723 -1.4503862)
(29.288161 3.8519444 -1.450854)
(29.287024 3.8538043 -1.4513087)
My updateCoeffs() function in my source code looks like:
void Foam::DSRFGVelocityFvPatchVectorField::updateCoeffs()
    if (this->updated())
        return;
    if (curTimeIndex_ != this->db().time().timeIndex())
    xxxxxxxxxx some calculation procedure
    this->operator==(Utotal);
    curTimeIndex_ = this->db().time().timeIndex();
    fixedValueFvPatchVectorField::updateCoeffs();
Can anyone help me with this?
XJ_Wang is offline   Reply With Quote
Old   March 27, 2023, 04:10
Sergey Lesnik
serles is on a distinguished road
Something is wrong with the I/O. During reading of fields from the disk, OpenFOAM constructs a dictionary from the file (processor1/0/U in your case), where the Lists are stored as compoundToken (since dictionary is able to work only with tokens). In the next step, this dictionary is supplied to the GeometricField constructor, whereby the List is transferred (not read from disk because it's already in memory) to the GeometricField instance.
I assume you didn't change the source code of renumberMesh. So the problem should be somewhere within the reading operations of your boundary condition. Can you provide the related members like "read" or "operator>>" from you BC?
serles is offline   Reply With Quote
Old   March 27, 2023, 22:16
Xiangjie Wang
Hi Sergey ,
Thanks for your reply. To be honest, I did not see any "read" members in my source code. Below is my updateCoeffs() member function:
        return;
    scalar time = this->db().time().value();
	vectorField& U = *this;
    vectorField Uavg(patch().size(),vector::zero);
    vectorField Uprim(patch().size(),vector::zero);
    //vectorField Utotal(patch().size(),vector::zero);
    scalar kx=0.;
        scalar vx=0.;
        scalar vy = 0.;
        scalar vz = 0.;
    forAll(patch().Cf(),faceI)
        scalar zcell=patch().Cf()[faceI][2];
        Uavg[faceI][0]=uref_*pow(zcell/zref_,alpha_);
        kx=0.;
        vx=0.;
        vy=0.;
        vz=0.;
        forAll(allK_,ki)
            kx=patch().Cf()[faceI][0]*allK_[ki][0]/Ls_[ki][0]+patch().Cf()[faceI][1]*allK_[ki][1]/Ls_[ki][1]+patch().Cf()[faceI][2]*allK_[ki][2]/Ls_[ki][2]+omega_[ki]*time;
            vx+=allP_[ki][0]*sin(kx)+allQ_[ki][0]*cos(kx);
            vy+=allP_[ki][1]*sin(kx)+allQ_[ki][1]*cos(kx);
            vz+=allP_[ki][2]*sin(kx)+allQ_[ki][2]*cos(kx);
        Uprim[faceI][0]=vx;
        Uprim[faceI][1]=vy;
        Uprim[faceI][2]=vz;
U=Uavg+Uprim;
I am also not sure of the autoMap and rmap member function. I just claimed the function but don't know how to use them. My code can run in single processor.
void Foam::DSRFGVelocityFvPatchVectorField::autoMap
    const fvPatchFieldMapper& m
    fixedValueFvPatchVectorField::autoMap(m);
void Foam::DSRFGVelocityFvPatchVectorField::rmap
    const fvPatchField& ptf,
    const labelList& addr
    fixedValueFvPatchVectorField::rmap(ptf, addr);
    const DSRFGVelocityFvPatchVectorField& tiptf =
        refCast<const DSRFGVelocityFvPatchVectorField>(ptf);
Thank you very much!!!
Old   March 29, 2023, 04:09
Sergey Lesnik
OK, then I assume you construct your BC with a dictionary, don't you? Anyway, can you provide the constructor you use?
What class do you inherit from?
Old   March 29, 2023, 12:06
Xiangjie Wang
Thank you very much Sergey!!!
You are correct! There is something wrong with my constructor. My BC inherits from fixedValue class and I used 'foamNewBC -f -v' to generate the templates of my BC dictionary. I am using Openfoam V6, but I modified my code according to a code from Openfoam v2112 so I changed my constructor. There is nothing wrong when I compiled my library but it just can not work well. Now I changed my constructor and it works!
A personal experience: I did not find too many similar problems in this forum, which means my problem is unusual and I might make something wrong at the first step.
Old   March 30, 2023, 05:21
Sergey Lesnik
You're welcome
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
"Failed Starting Thread 0" ebringley OpenFOAM Running, Solving & CFD 2 April 26, 2019 06:45
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 08:53
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
