OpenFOAM 10 - multiphaseEulerFoam compilation error
Old   February 15, 2023, 04:14
Default OpenFOAM 10 - multiphaseEulerFoam compilation error
Anonymous
palmera2 is on a distinguished road
Dear All,
I'm trying to compile the multiphaseEulerFoam of OpenFOAM 10 using the WSL utility without success. I have tried to copy the solver from source and compile it using the Allwmake script.
I have used the following commands:
 2008  cp -r $FOAM_APP/solvers/multiphase/multiphaseEulerFoam . 1>log.copy_solver 2>err.copy_solver
 2011  cd multiphaseEulerFoam/
 2013  ./Allwclean 1>log.Allwclean 2>err.Allwclean
 2015  ./Allwmake 1>log.Allwmake 2>err.Allwmake
 2016  history
I got the errors while compiling the phaseModel.c file because it couldn't find class Function1 (mind the capital F). A sample of the errors can be seen below:
wmakeLnInclude: linking include files to ../interfacialModels//lnInclude
wmakeLnInclude: linking include files to ../interfacialCompositionModels//lnInclude
wmakeLnInclude: linking include files to ../multiphaseCompressibleMomentumTransportModels//lnInclude
wmakeLnInclude: linking include files to ./lnInclude
In file included from /home/user/OpenFOAM/OpenFOAM-10/src/finiteVolume/lnInclude/MRFZone.H:51,
                 from /home/user/OpenFOAM/OpenFOAM-10/src/finiteVolume/lnInclude/MRFZoneList.H:41,
                 from /home/user/OpenFOAM/OpenFOAM-10/src/finiteVolume/lnInclude/IOMRFZoneList.H:54,
                 from lnInclude/phaseSystem.H:48,
                 from phaseModel/phaseModel/phaseModel.C:27:
../interfacialCompositionModels/lnInclude/Function1.H:99:17: error: ‘Function1’ was not declared in this scope; did you mean ‘function1’?
   99 |         autoPtr<Function1<scalar>> function_;
      |                 function1
In addition, I had other errors related to a certain field Omega:
/home/user/OpenFOAM/OpenFOAM-10/src/finiteVolume/lnInclude/MRFZoneTemplates.C: In member function ‘void Foam::MRFZone::makeRelativeRhoFlux(const RhoFieldType&, Foam::surfaceScalarField&) const’:
/home/user/OpenFOAM/OpenFOAM-10/src/finiteVolume/lnInclude/MRFZoneTemplates.C:44:26: error: ‘omega_’ was not declared in this scope; did you mean ‘Omega’?
   44 |     const vector Omega = omega_->value(mesh_.time().userTimeValue())*axis_;
      |                          Omega
Make/linux64GccDPInt32Opt/phaseModel/phaseModel/phaseModel.o] Error 1
Regarding the first group of errors, the class Function1 seems to be defined in a header file but I couldn't track it down.
#ifndef function1_H
#define function1_H
#include "saturationModel.H"
#include "Function1.H"
namespace Foam
namespace saturationModels
                          Class function1 Declaration
class function1
    public saturationModel
    // Private Data
        //- Saturation temperature as a function of pressure
public:
    //- Runtime type information
    TypeName("function1");
Could it be that I'm missing some dependencies for compiling the multiphaseEulerFoam solver?
I apologize in advance, as this is likely a basic mistake of mine in the compilation. The precompiled version of the solver works just fine.
Thanks in advance!
palmera2 is offline   Reply With Quote
Old   February 16, 2023, 09:24
Anonymous
Just as an update, the solver compiles fine if I'm using a Linux machine. Therefore, it could be a problem with copying files using the WSL virtual machine on Windows.
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
