IBS method for heat transfer
Old   January 27, 2023, 07:25
Default IBS method for heat transfer
Tiziano Santese
t.santese is on a distinguished road
Hi all,
I am trying to implement the IBS method in openfoam ext 4.1, using rhoPimpleFoam as solver.
I managed to implement everything that is needed to run with my solver the tutorial case "MovingCylinderInChannelTurbulent", however I still cannot include the energy equation.
if I give the following boundary condition for T, to the cylinder:
ibCylinder
type fixedValueIb;
patchType immersedBoundary;
triValue uniform 500;
setDeadValue yes;
deadValue 500;
value uniform 500;
the solver doesn't recognize the boundary condition and gives the following error, as soon as it enters the energy equation:
FOAM FATAL ERROR:
Not implemented
From function immersedBoundary::gradientInternalCoeffs()
in file lnInclude/fvPatchField.H at line 473.
FOAM aborting
Would you be so kind to help me out with this problem? Is it at all possible to use the IBS method including heat transfer? has anyone done something similar?
Thanks
t.santese is offline   Reply With Quote
ibm, ibs, immersedboundary
Unstructured Grid VS. Levet Set method VS. Immersed Boundary method aerosjc Main CFD Forum 5 November 29, 2022 21:23
Can immersed Boundary method in foam-extend-4.1 solve conjugate heat transfer? les3cd OpenFOAM Running, Solving & CFD 0 June 30, 2020 01:32
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 19:46
hess-smith method and fvm method yangqing FLUENT 0 March 20, 2002 20:25
