How to create a dictionary from a *char[]?
Old   January 24, 2023, 07:33
Default How to create a dictionary from a *char[]?
Jesus
jgs55 is on a distinguished road
Dear Foamers,
I have a pointer to an array of chars, which has the structure of a dictionary. I need to create a dictionary from that pointer, but I am not clear on how to do so.
I checked the dictionary constructor, and I can create it from a Istream object:
dictionary (Istream &is)
But I do not know how to convert the *char[] to Istream. Your help will be appreciated. Thanks in advance!
jgs55 is offline   Reply With Quote
constructor, dictionary, pointer
Dictionary in turbulence model NewKid OpenFOAM Programming & Development 4 February 18, 2019 22:16
create the file *.foam phongstar OpenFOAM 12 October 14, 2018 19:06
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 10:37
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary Struggle_Achieve OpenFOAM Pre-Processing 2 December 20, 2017 04:58
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
