d2dt2 on a patch
Old   January 12, 2023, 09:06
Default d2dt2 on a patch
ngbidi is on a distinguished road
Hi Foamers,
is there a way to get the second time derivative on a patch? I would like to calculate the second time derivative for the temperature. So far, I know how to calculate the second time derivative for the whole field with fvm::d2dt2. But I get a fvMatrix and I don't know how to continue with that.
Thanks in advance.
ngbidi is offline   Reply With Quote
Old   January 15, 2023, 07:53
Default solved
I found out the answer myself. I only need to use fvc::d2dt2 instead of fvm::d2dt2 and then I will get a volScalarField from which I can take the boundary values.
d2dt2, fvmatrix, patch, programming, second time derivative
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 459 September 12, 2024 12:47
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
