Create a volScalarField from a dictionary variable |
January 10, 2023, 12:30 |
Jesus
Rep Power: 5 |
Dear Foamers:
During the execution of my program, I create a dictionary with the same structure than p file, which means: Code:
{ dimensions [0 2 -2 0 0 0 0]; internalField uniform 101325; boundaryField { upperwall { type fixedFluxPressure; value $internalField; } lowerwall { type fixedFluxPressure; value $internalField; } column { type fixedFluxPressure; value $internalField; } inlet { type fixedFluxPressure; value $internalField; } outlet { type fixedValue; value $internalField; } defaultFaces { type empty; } } } |
January 11, 2023, 01:53 |
Rep Power: 4 |
According to the doxygen you have either the option of IOobject or a copy construct.
https://cpp.openfoam.org/v10/classFo...tricField.html |
January 13, 2023, 07:20 |
Mark Olesen
Rep Power: 40 |
Look for the "Construct from dictionary" in the header. Eg,
//- Construct from dictionary GeometricField ( const IOobject& io, const Mesh& mesh, const dictionary& dict ); Just make certain that your IOobject has the NO_READ option. |
dictionary, ioobject, volscalarfield |
How to create initiate a volScalarField p without reading from disk NO_READ does not seem to work | dbxmcf | OpenFOAM Running, Solving & CFD | 14 | March 25, 2022 06:08 |
Error Illegal dictionary entry or environment variable name | gotterstab | OpenFOAM | 0 | February 4, 2022 09:41 |
Unhandled variable DPM-dist | mahesh248f1 | FLUENT | 4 | July 15, 2021 10:50 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
