Can I establish two or more fvMatrix objects in one program?
Old   December 15, 2022, 06:35
Default Can I establish two or more fvMatrix objects in one program?
Chao Li
chaosCFD is on a distinguished road
Dear Foamers,
Does OpenFOAM allow to establish two fvMatrix objects in one program? I tried the following code:
	fvVectorMatrix DEqn1
            fvm::laplacian(impKf_, D(), "laplacian(DD,D)")
            - fvc::laplacian(impKf_, D(), "laplacian(DD,D)")
        fvVectorMatrix DEqn2
Info << "source of DEqn1: " << DEqn1.source() << endl;
Info << "source of DEqn2: " << DEqn2.source() << endl;
And the output is:
source of DEqn1: 4{(0 0 0)}
source of DEqn2: 4((0 0 0) (0 0 0) (0 0 0) (0 -27000 0))
Why the sources of the two fvMatrixes are different? They are established with the same parameters.
BTW, the fvc::laplacian(impKf_, D(), "laplacian(DD,D)") is:
dimensions      [1 -2 -2 0 0 0 0];
internalField   nonuniform List<vector> 4((0 0 0) (0 0 0) (0 0 0) (0 -180000 0));
boundaryField
    top
        type            zeroGradient;
    left
        type            zeroGradient;
    right
        type            zeroGradient;
    bottom
        type            zeroGradient;
    front
        type            empty;
    back
        type            empty;
chaosCFD is offline   Reply With Quote
Old   December 28, 2022, 22:45
Hrvoje Jasak
Why D(), ie why do you need brackets? Is there a memory leak, or a reference to temporary?
Try making a field D and repeat the exercise.it looks like your second D or second equation has got a fixedValue boundary condition on the bottom patch. I’m not sure how this happened.
There are always dozens of such matrices created all the time - this must work.
Hrv
Hrvoje Jasak
Old   January 3, 2023, 09:33
Chao Li
Hrv
Dear Prof. Jasak
D() returns a volVectorField D_. The definition is in the base class.
virtual volVectorField& D()
                return D_;
Is this way of writing more likely to cause memory leak?
development, fvmatrix, openfoam, solids4foam
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 04:32
fvMatrix, fvOptions and SuSp: automatic implicit/explicit source-term treatment Zeppo OpenFOAM Programming & Development 7 December 15, 2021 11:20
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
the openfoam source term and fvmatrix problem wenxu OpenFOAM Programming & Development 0 September 5, 2014 11:56
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
