problem in parallel with gradient term for langevin equation
Old   November 23, 2022, 17:22
Default problem in parallel with gradient term for langevin equation
Charles Guaquiere
CGuaq is on a distinguished road
Hello everyone,
I try to implement CRW model on OpenFOAM 9 based on Langevin equation and I need to add a drift term with gradient of sigma (in normal flow direction).
My recurrence equations for turbulent velocity components are:
This is my code, it's not over yet (in particular for backup variables that need to be defined out of the function for initialization).
template<class CloudType>
Foam::vector Foam::myStochasticModel<CloudType>::update
    const scalar dt,
    const label celli,
    const vector& U,
    const vector& Uc,
    vector& UTurb,
    scalar& tTurb
    Random& rnd = this->owner().rndGen();
    const scalar cps = 0.142857;
    const scalar UrelMag = mag(U - Uc - UTurb);
    const objectRegistry& obr = this->owner().mesh();
    const word turbName = IOobject::groupName
         momentumTransportModel::typeName,
         this->owner().U().group()
    const momentumTransportModel& turbModel = obr.lookupObject<momentumTransportModel>(turbName);
    scalar y_(wallDist::New(this->owner().mesh()).y()[celli]);
    const tmp<volScalarField> tk = turbModel.k();
    const volScalarField& k = tk();
    const tmp<volScalarField> tepsilon = turbModel.epsilon();
    const volScalarField& epsilon = tepsilon();
    const tmp<volScalarField> tnu = turbModel.nu();
    const volScalarField& nu = tnu();
    dimensionedScalar UTau("UTau",dimensionSet(0, 1, -1, 0, 0, 0, 0),0.32);
    dimensionedScalar tL("tL", dimensionSet(0, 0, 1, 0, 0, 0, 0), 0);
    dimensionedScalar Tp("Tp", dimensionSet(0, 0, 1, 0, 0, 0, 0), 0);
    dimensionedScalar nu_("nu_", dimensionSet(0, 2, -1, 0, 0, 0, 0), 0.000014607);
    dimensionedScalar k_("k_", dimensionSet(0, 2, -2, 0, 0, 0, 0), k[celli]);
    dimensionedScalar epsilon_("epsilon_", dimensionSet(0, 2, -3, 0, 0, 0, 0), epsilon[celli]);
    dimensionedScalar dp ("dp", dimensionSet(0, 1, 0, 0, 0, 0, 0), 1e-08);
    const scalar yStar = UTau.value()*y_/nu_.value();
    if (yStar >100)
    	tL=cps*k_/epsilon_;
    else
    	if (yStar > 5)
    		tL = (7.122+0.5731*yStar-0.00129*pow(yStar, 2))*nu_/pow(UTau, 2);
    	else
    		tL = 10*nu_/pow(UTau, 2);
    const scalar Te = 2*tL.value();
    const scalar Kn = (2.0*6.6e-08)/dp.value();
    const scalar Cc = 1 + Kn*(1.257 + 0.4*exp(-1.1/Kn));
    Tp = 2000*pow(dp , 2)*Cc/(18*nu_);
    const scalar Le = Te*sqrt(2*k[celli]/3);
    const scalar Dcross = Tp.value()*UrelMag;
    scalar tTurbLoc;
    if (Le < Dcross)
    	tTurbLoc =-Tp.value()*log(1-(Le/(Tp.value()*(UrelMag+ small))));
    else
    	tTurbLoc = Te;
    const scalar Stk=Tp.value()/tL.value();
/////////////////////backup variables to put out of the function////////////////////////////////////////////////
    scalar sigma_xn=1e-12;
    scalar sigma_yn=1e-12;
    scalar sigma_zn=1e-12;
    scalar sigma_n=1e-12;
    scalar u_xn=0;
    scalar u_yn=0;
    scalar u_zn=0;
    if (dt < tTurbLoc)
        	scalar lambda1 = mag(rnd.scalarNormal());
            	scalar lambda2 = mag(rnd.scalarNormal());
            	scalar lambda3 = mag(rnd.scalarNormal());
            	const scalar theta = rnd.sample01<scalar>()*twoPi;
            	const scalar u = 2*rnd.sample01<scalar>() - 1;
            	const scalar a = sqrt(1 - sqr(u));
            	if (yStar < 100.0)
            		const scalar sigma_x = (0.4*yStar)/(1+0.0239*pow(yStar, 1.496))*UTau.value();
            		const volScalarField sigma_y = (0.0116*pow(yStar, 2))/(1+0.203*yStar+0.0014*pow(yStar, 2.421))*UTau*nu/nu;
            		const scalar sigma_z = (0.19*yStar)/(1+0.0361*pow(yStar, 1.322))*UTau.value();
            		const volVectorField gradSigmaVol = fvc::grad(sigma_y);
            		const volScalarField gradSigmaY = gradSigmaVol.component(vector::Y);
            		const scalar u_x = (sigma_x/sigma_xn)*u_xn*exp(-dt/tL.value())+sigma_x*sqrt(1-exp(-2*dt/tL.value()))*lambda1;
            		const volScalarField u_y = (sigma_y/sigma_yn)*u_yn*exp(-dt/tL.value())+sigma_y*sqrt(1-exp(-2*dt/tL.value()))*lambda2+(tL*sigma_y)/(1+Stk)*(1-exp(-dt/tL.value()))*gradSigmaY;
            		const scalar u_z = (sigma_z/sigma_zn)*u_zn*exp(-dt/tL.value())+sigma_z*sqrt(1-exp(-2*dt/tL.value()))*lambda3;
            		const vector dir(u_x*a*cos(theta), u_y[celli]*a*sin(theta), u_z*u);
            		UTurb = dir;
            		u_xn = u_x;
            		u_yn = u_y[celli];
            		u_zn = u_z;
            		sigma_xn = sigma_x;
            		sigma_yn = sigma_y[celli];
            		sigma_zn = sigma_z;
            	else
            		const scalar sigma = sqrt(2*k[celli]/3.0);
            		const volScalarField sigmaVol = sqrt(2*k/3.0);
            		const volVectorField gradSigmaVol = fvc::grad(sigmaVol);
            		const scalar u_x = (sigma/sigma_n)*u_xn*exp(-dt/tL.value())+sigma*sqrt(1-exp(-2*dt/tL.value()))*lambda1;
            		const volScalarField u_y = (sigmaVol/sigma_n)*u_yn*exp(-dt/tL.value())+sigmaVol*sqrt(1-exp(-2*dt/tL.value()))*lambda2+(tL*sigmaVol)/(1+Stk)*(1-exp(-dt/tL.value()))*gradSigmaY;
            		const scalar u_z = (sigma/sigma_n)*u_zn*exp(-dt/tL.value())+sigma*sqrt(1-exp(-2*dt/tL.value()))*lambda3;
            		UTurb = dir;
            		u_xn = u_x;
            		u_yn = u_y[celli];
            		u_zn = u_z;
            		sigma_n = sigma;
    else
        UTurb = Zero;
        u_xn = 0;
        u_yn = 0;
        u_zn = 0;
        sigma_xn = 1e-12;
        sigma_yn = 1e-12;
        sigma_zn = 1e-12;
        sigma_n =1e-12;
    return Uc + UTurb;
My code works with 1 processor but when I launch in parallel I get the following error message when particles are injected in the flow:
This error disappeared when I delete gradient term, I don't really understand why. Can someone help me to solve this problem ?
Thank you very much.
CGuaq is offline   Reply With Quote
Old   November 29, 2022, 06:05
Charles Guaquiere
I resolved my problem with gradient, but now I have a last problem to save values of UTurb and sigma components for the next time step.
I created 2 volVectorFiels in the constructor (u_n to save UTurb components values and sigma_n for sigma components) initialized to Zero:
sigma_n
	IOobject
		"sigma_n",
		this->owner_.mesh().time().timeName(),
		this->owner_.mesh(),
		IOobject::NO_READ,
		IOobject::AUTO_WRITE
	dimensionedVector("sigma_n", dimless, vector(10e-12, 10e-12, 10e-12))
    u_n
	IOobject
		"u_n",
		IOobject::NO_READ,
	dimensionedVector("u_n", dimless, vector(0, 0, 0))
Now my problem is to modified this volVectorFields in each cells and for each time steps. I use the following lines to access to values in cells in volVectorFields:
const volVectorField& sigma_n = obr.lookupObject<volVectorField>("sigma_n");
volVectorField& sigma_nMod = const_cast<volVectorField&>(sigma_n);
const volVectorField& u_n = obr.lookupObject<volVectorField>("u_n");
volVectorField& u_nMod = const_cast<volVectorField&>(u_n);
And futher I modify the values in each cells with:
u_nMod.primitiveFieldRef()[celli].component(0) = UTurb.component(0);
u_nMod.primitiveFieldRef()[celli].component(1) = UTurb.component(1);
u_nMod.primitiveFieldRef()[celli].component(2) = UTurb.component(2);
sigma_nMod.primitiveFieldRef()[celli].component(0) = sigma_x;
sigma_nMod.primitiveFieldRef()[celli].component(1) = sigma_y;
sigma_nMod.primitiveFieldRef()[celli].component(2) = sigma_z;
I can compile my code and lauch simulation without errors but it doesn't seem to work ...
Did you have another solution to modified volVectorField or volScalarField cell by cell at each time step ? Or maybe help me to find the error in my code ? I'am beginner in programming under OpenFOAM so any idea could be helpful for me !
Old   November 29, 2022, 06:13
Default VolVectorField
csimr
csimr is on a distinguished road
hello,
I have the same problem with VolVectorField. there is someone who has worked with this model before ?
csimr is offline   Reply With Quote
Old   July 10, 2024, 10:00
Default CRW model equations
Rui Carneiro
sinvastil is on a distinguished road
Hi Charles,
I wonder if you have solved your problem and if you achieved satisfactory results using the CRW model?
One more question, from which source have you taken the CRW integrated equations shown in the image of the first post?
Thank you.
Regards
sinvastil is offline   Reply With Quote
Old   July 11, 2024, 08:14
Charles Guaquiere
Hi sinvastil,
The equations comes from the article of Ahmadi & Mofakham intitled "Improved discrete random walk stochastic model for simulating particle dispersion and deposition in inhomogeneous turbulent flow", you can also find some informations in the other articles from them. But this post is old and I modified this equations by considering the results from the article "stochastic modeling of particle diffusion in a turbulent boundary layer". I obtained very good results with this new model for academic cases but also in more complex flows.
Finally,what problem are you interested in?
Regards
Old   July 12, 2024, 05:21
Rui Carneiro
Hi Charles,
At the moment, I am just exploring the possibility to implement it in OpenFOAM because of the reported limitations of the DRW. Basically, I am looking at the equations, literature, and look for people's opinion about the accuracy of the model for more complex scenarios. So I am glad you got good results for complex flows.
Next, since to my knowledge the code is not available online, I will evaluate the steps I need for the implementation in OpenFOAM. Therefore, it is likely that I will ask some support in the near future.
Thank you.
Regards
Old   July 12, 2024, 06:59
Charles Guaquiere
Hi sinvastil,
Indeed this model is quit difficult to implement depending on your knowledge on OpenFOAM. I will publish an article in the next few weeks on this subject and the application to more complex flows.
After that, I will share my code via gitHub, it is far from perfect and could be improved on certain points. If you need you can use it or participate in its improvement.
Old   July 12, 2024, 09:31
Rui Carneiro
Hi Charles,
In terms of programming in OpenFOAM I am still a beginner never programmed such model, only small code modications.
That would be very nice, in that way I can hopefully contribute to the improvement of the code instead of writing it from scratch and struggle with the same things that you already did.
I look forward to read your article and test the code. We keep in touch and good luck for the coming weeks.
Regards.
Adding diffusion term to interFoam transport equation Gearb0x OpenFOAM Programming & Development 3 February 14, 2023 05:16
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
viscosity term in discetrization momentum equation hans-186 Main CFD Forum 4 April 1, 2013 14:34
Pressure work term in turbulent K.E. equation lost.identity Main CFD Forum 0 March 8, 2011 13:21
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
