Problem while compiling ccmToFoam with wmake
Old   November 21, 2022, 10:58
Post Problem while compiling ccmToFoam with wmake
mf47 is on a distinguished road
Hello guys,
I am trying to compile the application for mesh conversion "ccmToFoam" by using the wmake command, but it is not working. Am I missing something? The output is as follows:
$ wmake
x86_64-w64-mingw32-g++ -std=gnu++11 -m64 -pthread -DOPENFOAM=2106 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNDEBUG -DNoRepository -ftemplate-depth-100 -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/finiteVolume/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/fileFormats/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/meshTools/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/conversion/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/conversion/ccm/lnInclude -iquote. -IlnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v2106/src/OSspecific/MSwindows/lnInclude -Wl,--enable-auto-import -Wl,--strip-all -Wl,--force-exe-suffix -L/home/ofuser/OpenFOAM/OpenFOAM-v2106/platforms/win64MingwDPInt32Opt/lib \
-lfiniteVolume -lgenericPatchFields -lmeshTools -lconversion -lccm -lOpenFOAM -L/home/ofuser/OpenFOAM/OpenFOAM-v2106/platforms/win64MingwDPInt32Opt/lib/dummy -lPstream \
-DNDEBUG -lm -o OpenFOAM.out.exe
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lfiniteVolume: No such file or directory
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lgenericPatchFields: No such file or directory
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lmeshTools: No such file or directory
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lconversion: No such file or directory
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lccm: No such file or directory
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lOpenFOAM: No such file or directory
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lPstream: No such file or directory
collect2.exe: error: ld returned 1 exit status
make: *** [/home/ofuser/OpenFOAM/OpenFOAM-v2106/wmake/makefiles/general:150: OpenFOAM.out.exe] Error 1
It seems that some files/directories are not available, but the application "ld.exe" is in the correct directory.
Can you help me with this problem?
PS.: I am using WSL on Windows.
mf47 is offline   Reply With Quote
Old   December 8, 2022, 05:26
Kuralamuthan Veerapandiyan
Kuralamuthan is on a distinguished road
Can you share the contents of Make/files and Make/options files here? Confirm whether you have sourced the bashrc file before running the wmake command.
Kuralamuthan is offline   Reply With Quote
Old   December 12, 2022, 08:17
Hello Kuralamuthan. Thank your for replying.
I found the following contents in the files you mentioned:
Make/files:
ccmToFoam.C
EXE = $(FOAM_APPBIN)/ccmToFoam
Make/options:
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/fileFormats/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/conversion/lnInclude \
-I$(LIB_SRC)/conversion/ccm/lnInclude
EXE_LIBS = \
-lfiniteVolume \
-lgenericPatchFields \
-lmeshTools \
-lconversion -lccm
However, it seems that the package ccmToFoam is paid now. Is there any alternative for mesh conversion such as using CGNS format? If so, do you know how can I install this package?
application, ccmtofoam, windows, wmake
[OpenFOAM.org] wmake problem vville OpenFOAM Installation 1 October 8, 2015 06:01
code compilation problem with wmake bmikuz OpenFOAM Programming & Development 2 October 17, 2012 10:30
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
Wmake problem thumthae OpenFOAM Installation 12 December 3, 2008 10:30
Compiling Problem on Debian besto OpenFOAM Installation 8 August 13, 2008 16:29
