November 21, 2022, 08:23 |
overset library integration to OpenFOAM
Rep Power: 7 |
Dear Foamers,
When i realized that overset talents of foam extend (version 5.0) is better than Openfoam (v1912), i decided to implement overset library of foam-extend to ESI version. But there is a error appears whatever i try: Code:
wmake libso (oversetMesh) ln: ./lnInclude make: *** No rule to make target `Make/linux64GccDPInt32Opt/../oversetRegion/oversetRegion.C.dep', needed by `Make/linux64GccDPInt32Opt/../oversetRegion/oversetRegion.o'. Stop 1- I copied 'src' file of foam-extend to $WM_PROJECT_USER_DIR in ESI version. So new 'src' is placed in $WM_PROJECT_USER_DIR/src 2- With a code, i changed all the 'WM_PROJECT_DIR' terms to 'WM_PROJECT_USER_DIR' in each .deb files in src 3-I want to take advantage from oversetMesh library which is under $WM_PROJECT_USER_DIR/src/overset/oversetMesh/oversetMesh Therefore, in Make file, i did these modifications: Make/files: Code:
../oversetRegion/oversetRegion.C ../oversetFringe/oversetFringe/oversetFringe.C ../oversetFringe/oversetFringe/newOversetFringe.C ../oversetFringe/manualFringe/manualFringe.C ../oversetFringe/faceCellsFringe/faceCellsFringe.C ../oversetFringe/donorBasedLayeredOverlapFringe/donorBasedLayeredOverlapFringe.C ../oversetFringe/cuttingPatchFringe/cuttingPatchFringe.C ../oversetFringe/overlapFringe/overlapFringe/overlapFringe.C ../oversetFringe/overlapFringe/layeredOverlapFringe/layeredOverlapFringe.C ../oversetFringe/overlapFringe/adaptiveOverlapFringe/adaptiveOverlapFringe.C ../oversetFringe/compositeFringe/compositeFringe.C ../oversetFringe/overlapFringe/donorSuitability/donorSuitability/donorSuitability.C ../oversetFringe/overlapFringe/donorSuitability/donorSuitability/newDonorSuitability.C ../oversetFringe/overlapFringe/donorSuitability/noSuitability/noSuitability.C ../oversetFringe/overlapFringe/donorSuitability/patchDistance/patchDistance.C ../oversetFringe/overlapFringe/donorSuitability/cellVolumes/cellVolumes.C ../oversetFringe/overlapFringe/donorSuitability/faceArea/faceArea.C ../oversetFringe/overlapFringe/donorSuitability/cellBoundingBoxDiagonal/cellBoundingBoxDiagonal.C ../oversetInterpolation/oversetInterpolation/oversetInterpolation.C ../oversetInterpolation/oversetInterpolation/newOversetInterpolation.C ../oversetInterpolation/injectionInterpolation/injectionInterpolation.C ../oversetInterpolation/inverseDistanceInterpolation/inverseDistanceInterpolation.C ../oversetInterpolation/averageValueInterpolation/averageValueInterpolation.C ../oversetMesh/oversetMesh.C ../oversetMesh/oversetMeshAddressing.C ../oversetLduInterface/oversetLduInterface.C ../oversetLduInterfaceField/oversetLduInterfaceField.C ../oversetAMGInterface/oversetAMGInterface.C ../oversetAMGInterfaceField/oversetAMGInterfaceField.C ../oversetPolyPatch/oversetPolyPatch.C ../oversetPointPatch/oversetPointPatch.C ../oversetFvPatch/oversetFvPatch.C ../oversetFvPatchField/oversetFvPatchFields.C ../oversetFvPatchField/emptyOversetFvPatchField/emptyOversetFvPatchFields.C ../oversetFvsPatchField/oversetFvsPatchFields.C ../oversetAdjustPhi/oversetAdjustPhi.C ../oversetAdjustPhi/globalOversetAdjustPhi.C ../oversetAdjustPhi/regionWiseOversetAdjustPhi.C LIB = $(FOAM_USER_LIBBIN)/liboversetMesh Code:
EXE_INC = \ -I$(WM_PROJECT_USER_DIR)/src/finiteVolume/lnInclude \ -I$(WM_PROJECT_USER_DIR)/src/surfMesh/lnInclude \ -I$(WM_PROJECT_USER_DIR)/src/meshTools/lnInclude \ -I$(WM_PROJECT_USER_DIR)/src/sampling/lnInclude LIB_LIBS = \ -lfiniteVolume \ -lmeshTools \ -lsurfMesh \ -L$(FOAM_USER_LIBBIN) \ -lsampling I think due to the beauty of object orienration, i don't need to wmake all files under $WM_PROJECT_USER_DIR/src. Because each file has lnInclude file which is compiled under foam-extend version anyway. So there are dependency linkages for .H files under lnInclude files. Am i thinking as wrong? If you can enlighten me, i would be very grateful because i am kind of loss right now. Have good days! Halil |
foam-extend 5.0, openfoam 1912, overset library |
how to link the path of a newly compiled library to another library in OpenFOAM | sourav8016 | OpenFOAM | 3 | December 28, 2023 16:21 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
