How to add turbulence model and VOF to a new two-step projection OpenFOAM solver |
October 30, 2022, 09:36 |
Shuo Mi
Rep Power: 6 |
Hello everyone,
I wrote an OpenFOAM solver using two steps projection method, not using original PISO or PIMPLE in OpenFOAM. The second-order Adams-bashforth for time scheme is used. Code:
fvVectorMatrix UEqn ( fvm::ddt(U) + 1.5*fvc::div(phi, U) - 0.5*fvc::div(phi.oldTime(), U.oldTime()) == 1.5*fvm::laplacian(nu, U) - 0.5*fvc::laplacian(nu, U) + 0.5*fvc::grad(p) ); fvScalarMatrix pEqn ( fvm::laplacian(p) == 2.0/3.0*fvc::div(phi)/dt ); 1. How to add turbulence model? Is it right that using nuEff() to replace the nu directly? 2. How to add VOF model? I have no idea about this. Thanks a lot! Regards, Shuo |
November 3, 2022, 16:08 |
Federico Zabaleta
Rep Power: 10 |
Hello Msure
1- You should check out the implementation of turbulence in other models, such as pisoFoam. It is done by creating a pointer in createFields.H that points to the selected turbulent closure. Then the function turbulence->divDevReff(U) is used to obtain the viscous and turbulent stresses. You can replicate this procedure in your solver. Check that other functions are used throughout the solver to, for example, solve the turbulent closure equations. You can take a look a this presentation for more information. 2- To add VOF take a look at the implementation of interFoam. You can check this thesis to see details of the implementation. I hope this helps, Federico |
November 3, 2022, 16:24 |
Shuo Mi
Rep Power: 6 |
thanks Federico, these documents are useful.
openfoam, turbulence models, vof |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 5 | November 22, 2024 07:32 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 6, 2018 00:48 |
Which solver in OpenFOAM corresponds to the Eulerian Model in FLUENT? | paradism | OpenFOAM | 1 | March 20, 2017 10:35 |
Help Selecting Turbulence Model for VOF Problem | NavierIsStoked | FLUENT | 0 | November 1, 2013 12:27 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 23:00 |
