Problems installing waves2Foam extension
Old   October 28, 2022, 13:18
Default Problems installing waves2Foam extension
Jaime Martins-Barata
JaimeMB is on a distinguished road
Dear all,
I have been trying for the past week to install waves2Foam to perform NWT simulations for my final year university project, however, all attempts have been unsuccessful. I am using a Mac (macOS Big Sur v11.4 silicon chip), I have installed all the required third party dependencies (git (v2.33.0), gfortran, GNU science library and svn (installed using brew)), I am running OpenFoam 10 (on which I have already run and post-processed a couple of tutorial simulations). Whenever I attempt to run the command ./Allwmake I get the following error message:
COMPILE OCEANWAVE3D
Pull changes from the OceanWave3D git repository ...
Saved working directory and index state WIP on master: bb7d99e bug fix for calling OceanWave3D
Already up to date.
On branch master
Your branch is up to date with 'origin/master'.
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git restore <file>..." to discard changes in working directory)
modified: common.mk
modified: makefile
no changes added to commit (use "git add" and/or "git commit -a")
Dropped refs/stash@{0} (0d899fd10c35773ec3c6cd8f6693e2a11fcc2411)
Set the environmental variables for waves2Foam
Exiting compilation process
Problems with the compilation of the third party dependencies
Exiting
Before attempting to use waves2Foam, I tried using OlaFlow but also found myself having problems with compilation (this time compiling the solvers). If you have any idea on how to solve this problem, or any alternative 2D & 3D NWT simulators please do not hesitate to contact me.
Thank you, Jaime MB
JaimeMB is offline   Reply With Quote
[foam-extend.org] Problems on installing Foam-extend 4.0/ swak4Foam on ubuntu18.0.4 XJ_Wang OpenFOAM Installation 22 December 19, 2021 08:55
[foam-extend.org] Problems installing the FSI-toolkit on foam-extend-4.0 Elstro OpenFOAM Installation 0 June 20, 2021 18:50
[waves2Foam] installing waves2foam into OpenFoam 6 madgeogr OpenFOAM Community Contributions 1 June 15, 2021 12:17
[OpenFOAM.com] v3.0+ Problems installing on Ubuntu 16.04 Evander OpenFOAM Installation 3 March 26, 2017 15:47
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 sam.ho OpenFOAM Installation 35 April 5, 2014 16:31
