Looping over faceCellZone
Old   September 20, 2022, 10:32
Default Looping over faceCellZone
Horst van Gras
HorstvanGrass is on a distinguished road
I defined using topoSet at faceZone. I'm developing a custom function where I want to call the faceZone and loop over the faces.
Howeever when I call:
Foam::faceZoneSet testFS =     Foam::faceZoneSet(mesh,"test");
I recieve an function deleted error
error: use of deleted function ‘Foam::faceSet::faceSet(const Foam::faceSet&)
HorstvanGrass is offline   Reply With Quote
Old   September 21, 2022, 03:30
Horst van Gras
Found the error. Cannot predefine the function and later calling it.
        Foam::faceZoneSet testFS(mesh,"test");
faceset, facezone, openfoam
How looping over cells works in FLUENT UDFs? Cooper24 Fluent UDF and Scheme Programming 2 August 10, 2022 06:17
Looping macro for DPM hjubaer Fluent UDF and Scheme Programming 7 July 8, 2019 23:18
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
Looping over all faces within a boundary condition (turbulent inlet development) Sevex OpenFOAM Programming & Development 5 September 8, 2016 14:58
looping over selected / marked cells Jonathan Fluent UDF and Scheme Programming 0 November 22, 2012 05:59
