Reading a volumeField from a file at every timestep
Old   September 20, 2022, 08:37
Default Reading a volumeField from a file at every timestep
Jesus
jgs55 is on a distinguished road
Hi everyone,
I want to implement a new discretization scheme for the convective term in OpenFOAM. At every timestep, I have a coefficient file generated by python with the format:
... header
internalField   nonuniform List<vector>
16384
(1.03544e-05 -1.06153e-05 1.03544e-05 1.03544e-05 ) // Cell 0
(3.06175e-05 -1.01041e-05 -1.01041e-05 -1.01041e-05) // Cell 1
(5.11404e-05 -9.46919e-06 -9.46919e-06 -9.46919e-06) // Cell 2
(7.20913e-05 -9.58538e-06 -9.58538e-06 -9.58538e-06 ) // ...
(9.31207e-05 -9.87433e-06 -9.87433e-06 -9.87433e-06 )
(0.000115088 -1.02901e-05 -1.02901e-05 -1.02901e-05 )
I need to read the file "coefficients" like any other field (e.g. u,p,k,etc) but at every timestep and load it to OpenFOAM as a volumeField.
I guess I should implement this on the runTime.loop(), since createFields.H is only executed once at the beginning of the main loop, but I do not have a clear idea of how to do that.
Thank you in advance!
jgs55 is offline   Reply With Quote
Old   September 21, 2022, 02:58
Sen Wang
wangsen992 is on a distinguished road
Have you tried including this as a volVectorField (just like U) but in the arguments for IOobject, use MUST_READ_IF_MODIFIED?
wangsen992 is offline   Reply With Quote
Old   September 21, 2022, 08:37
Jesus
Thank you Mr Wang for your reply, it was what I was looking for. For anyone with the same doubt, the solution was to modify the createFields.H of your solver, and add the following lines:
volVectorField coefficients
    IOobject
        "coefficients",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ_IF_MODIFIED, //If object is registered its timestamp will be checked every timestep and possibly re-read.
        IOobject::NO_WRITE  //No automatic writing, but can be written explicitly
    mesh
createfields, new implementation, read fields
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 09:27
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
