Average of Uprime2Mean(Reynolds stresses) in time and Uprime3mean definition
Old   August 3, 2022, 11:19
Default Average of Uprime2Mean(Reynolds stresses) in time and Uprime3mean definition
Farzad Faraji
farzadmech is on a distinguished road
Hello all
I want to average prime2Mean in time. There must be two options;
1- Adding new volScalarfield named RXX,RYY,RZZ,.... an then average in time(This should work fine)
2- Since we have generated Uprime2Mean already in U section, we may average it as a new parameter again without adding RXX,RYY,RZZ,.... .
Also I want to define Uprime3mean which is the third moment of velocity. I believe it must be defined in "libfieldFunctionObjects.so", but I can find the file to define this new parameter.
Do you have any suggestion for my questions?
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         20;
deltaT          0.2;
writeControl    timeStep;
writeInterval   10;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    fieldAverage1
        type            fieldAverage;
        libs            ("libfieldFunctionObjects.so");
        writeControl    writeTime;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
farzadmech is offline   Reply With Quote
Old   August 3, 2022, 11:30
Default hi
sina
aghsin is on a distinguished road
uprime2Mean is already averaged in time. why do you want to average again?
aghsin is offline   Reply With Quote
Old   August 3, 2022, 14:05
Farzad Faraji
You are right, it is already averaged. What about Uprime3mean? Where is the function object file so I can modify it?
Thanks,
Farzad
Originally Posted by aghsin View Post
Old   August 3, 2022, 19:40
Agustín Villa
agustinvo is on a distinguished road
Thanks,
Farzad
Do you mean a rank 3 tensor? I saw something about that a long time ago (at least in the programming guide they are mentioned) in the code, but it was not implemented or I never knew how to use it.
agustinvo is offline   Reply With Quote
Old   August 3, 2022, 23:19
Farzad Faraji
I want R111,R222,R333 and etc.
Farzad
Old   August 4, 2022, 00:10
Farzad Faraji
My main question is that where is Reynolds stresses defined? I found libfieldFunctionObjects but I did not see where Reynolds stresses has been defined. I want to add my definition there.
Thanks,
Farzad
Farzad
Old   August 5, 2022, 14:53
Agustín Villa
The Reynolds stress tendor is defined in the turbulence model library. If you are using a eddy viscosity model R is not callable unless you use the turbulenceFields functioObject. If you are using a Reynolds stress model you would have no problems.
The problem you might have when computing the UPrime3Mean is that there are no rank three volFields. You should somehow load U and UMean and define your third momentum tensor instantaneously, but you should create three tensor fields and average them in time. Check the fieldAverage function to help you with that.
openfoam, time-averaged, uprime2mean, uprime3mean
