SRF compressible rhoSimpleFoam
Old   August 1, 2022, 07:17
Default SRF compressible rhoSimpleFoam
Zeinab Abosedaira
ZeinabM is on a distinguished road
Hello, I hope you're doing well. So, now there is a task required from me to edit rhoSimpleFoam solver to accommodate the SRF model. I copied the solver to my application file and performed some edits. Also, I have done some edits in the SRFModel.H and SRFModel.C. I compile the new solver and everything is good, when I get to use it with a problem, it gives me an error of inconsistent units. I've successfully known where the inconsistency happens but I don't why.
--> FOAM FATAL ERROR: (openfoam-2012)
    [Urel[1 -2 -2 0 0 0 0] ] + [(Fcoriolis+Fcentrifugal)[0 1 -2 0 0 0 0] ]
    From void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::DimensionedField<Type, Foam::volMesh>&, const char*) [with Type = Foam::Vector<double>]
    in file /opt/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/lnInclude/fvMatrix.C at line 1351.
FOAM aborting
I put some flags to know where the error is, and it turned out that it happens when solving the Urel equation.
  tmp<fvVectorMatrix> tUrelEqn
        fvm::div(phi, Urel)
        + SRF -> SuCompressible()
        + turbulence->divDevRhoReff(Urel)
        fvOptions(rho, Urel)
Below I am sharing SRFModel.C, the lines in bold are the edited lines:
#include "SRFModel.H"
#include "SRFVelocityFvPatchVectorField.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    namespace SRF
        defineTypeNameAndDebug(SRFModel, 0);
        defineRunTimeSelectionTable(SRFModel, dictionary);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::SRF::SRFModel::SRFModel
    const word& type,
    const volVectorField& Urel,
    const volScalarField& rho
    IOdictionary
        IOobject
            "SRFProperties",
            Urel.time().constant(),
            Urel.db(),
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    Urel_(Urel),
    rho_ (rho),
    mesh_(Urel_.mesh()),
    origin_("origin", dimLength, get<vector>("origin")),
    axis_(normalised(get<vector>("axis"))),
    SRFModelCoeffs_(optionalSubDict(type + "Coeffs")),
    omega_(dimensionedVector("omega", dimless/dimTime, Zero))
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::SRF::SRFModel::~SRFModel()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
bool Foam::SRF::SRFModel::read()
    if (regIOobject::read())
        // Re-read origin
        readEntry("origin", origin_);
        // Re-read axis
        readEntry("axis", axis_);
        axis_.normalise();
        // Re-read sub-model coeffs
        SRFModelCoeffs_ = optionalSubDict(type() + "Coeffs");
        return true;
    return false;
const Foam::dimensionedVector& Foam::SRF::SRFModel::origin() const
    return origin_;
const Foam::vector& Foam::SRF::SRFModel::axis() const
    return axis_;
const Foam::dimensionedVector& Foam::SRF::SRFModel::omega() const
    return omega_;
Foam::tmp<Foam::DimensionedField<Foam::vector, Foam::volMesh>>
Foam::SRF::SRFModel::FcoriolisCompressible() const
    return tmp<volVectorField::Internal>
        new volVectorField::Internal
            IOobject
                "FcoriolisComp",
                mesh_.time().timeName(),
                mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            rho_* 2.0*omega_ ^ Urel_
Foam::SRF::SRFModel::FcentrifugalCompressible() const
            IOobject
                "FcentrifugalComp",
                mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            rho_ *omega_ ^ (omega_ ^ (mesh_.C() - origin_))
Foam::SRF::SRFModel::SuCompressible() const
    return FcoriolisCompressible() + FcentrifugalCompressible();
The problem might be in the process of incorporating the rho in the SRFModel files, but I don't know exactly where it is.
ZeinabM is offline   Reply With Quote
Old   August 3, 2022, 08:54
Kuba
Ununul is on a distinguished road
The problem is coming from dimensions inconsistency. Are you sure that your Urel variable should have dimension kg m^-2 s^-2?
Greetings
Ununul is offline   Reply With Quote
compressible, rhosimplefoam, srf
rhoSimpleFoam: Does it work with SRF problems? ZeinabM OpenFOAM Running, Solving & CFD 2 July 28, 2022 06:55
rhoSimpleFoam for sub-sonic compressible aerodynamics. bentkj OpenFOAM Running, Solving & CFD 6 October 1, 2018 04:18
rhoSimpleFoam with SpalartAllmaras model for compressible flow usc2018 OpenFOAM Running, Solving & CFD 0 May 7, 2018 20:01
Compressible 2D airfoil rhoSimpleFoam fatal error volScalarField none jfournier OpenFOAM Running, Solving & CFD 4 September 28, 2017 07:28
how is rhoSimpleFoam a compressible steady statefor compressible flow cleoo OpenFOAM Pre-Processing 2 September 22, 2016 04:23
