RANS turbulence model with curvature correction |
July 24, 2022, 04:03 |
Feng
Rep Power: 9 |
Hi, fomers
I am doing a propeller simulation by using a nonlinear k-epsilon model (ShihQuadraticKE in new version OpenFoam). Considering the blades rotation and tip vortex flows, maybe a curvature correction should be implemented. In this paperhttps://research.chalmers.se/publica...4_Fulltext.pdf, a curvature correction method was employed in SST k-omega model, and I want to use this correction in ShihQuadraticKE turbulence model, but I am confused with the following two questions: 1) In the reference, the production term of the Omega equation is multiplied by correction function Frc. Mimic this method, can the correction function Frc be multiplied by the production term of Epsilon equation? 2) In this paper, The Wij tensor which associates the effects of curvature corrections in the rotational rate tensor is defined by (Eq. (9), (10) and (11)). I am not familiar with the expression of tensors. The big question is that the above three equations are tensor form, how to translate it to vector form, so they can be easily implemented in Openfoam. (p.s. Sorry I don't have permission to post pictures in the thread, please see the link https://research.chalmers.se/publica...4_Fulltext.pdffor the specific formula) Any help is welcomed, Thanks! |
curvature correction, rans, turbulence model |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
Trying to understand the grid requirement for RANS, DES and ELES turbulence model | dinhanh | FLUENT | 1 | December 23, 2014 04:27 |
Can RANS turbulence model be used to check the validity of Reynolds Analogy? | keryfluid | Main CFD Forum | 0 | April 22, 2013 23:48 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 04:20 |
