Calling MPI routines in OpenFOAM
Old   July 19, 2022, 07:22
Default Calling MPI routines in OpenFOAM
Doğukan Teber
dogukanteber is on a distinguished road
I have been trying to parallelize the decomposePar utility in OpenFOAM, for more information. Therefore, I need to call MPI routines in my new utility. I learned that OpenFOAM has Pstream wrapper for MPI routines. However, my program throws an error when I do not call decomposePar before I run the program. For instance, below is a basic hello world program:
#include "fvCFD.H"
 int main(int argc, char* argv[]) {
   #include "setRootCase.H"
   #include "createTime.H"
   // cannot run in parallel without creating processor0 directory
   Pout << "Hello from process " << Pstream::myProcNo() << endl;
   return 0;
Here are the commands that I execute in order (assume I have compiled my source file):
blockMesh
mpirun -np 4 <program-name> -parallel
And, here is the error message:
Pstream initialized with:
   floatTransfer   : 0
   nProcsSimpleSum  : 0
   commsType     : nonBlocking
   polling iterations : 0
 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
 allowSystemOperations : Allowing user-supplied system call operations
 [0]
 [0]
 [0] --> FOAM FATAL ERROR: (openfoam-2106)
 [0] parallelDecompose: cannot open case directory "/home/dogukan/Documents/hydrology/tutorials/permaFoam/demoCase/processor0"
 [0]
 [0]
 FOAM parallel run exiting
 [0]
 MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
 with errorcode 1.
 NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
 You may or may not see output from other processes, depending on
 exactly when Open MPI kills them.
When I call below functions, everything works as expected:
blockMesh
decomposePar
"I want to run my program after I call blockMesh so that I can parallelize the decomposePar utility. Is it possible to use Pstream methods without calling the decomposePar utility?
OpenFOAM version: v2106
Thanks in advance
dogukanteber is offline   Reply With Quote
Old   July 19, 2022, 07:28
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
disable processor checks:
https://www.openfoam.com/documentati...d8510fdfc1ab7e
argList::noCheckProcessorDirectories();
olesen is offline   Reply With Quote
Old   July 19, 2022, 09:23
Doğukan Teber
Thank you so much olesen. I have solved my problem. I do have another question, though. When I run the below program, it waits for the process 0 and does not terminate:
Source Code:
#include "fvCFD.H"
    argList::addNote
        "Decompose a mesh and fields of a case in parallel execution"
    argList::addOption
        "decomposeParDict",
        "file",
        "Use specified file for decomposePar dictionary"
    scalar p_no = UPstream::myProcNo();
    if (p_no == 0 ) {
    Pout << "Hello from process " << p_no << endl;
    return 0;
Output:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
[1] Hello from process 1
[2] Hello from process 2
[3] Hello from process 3
Create time
--> FOAM Warning :
    From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType)
    in file db/IOstreams/IOstreams/IOstreamOption.C at line 115
    Unknown compression specifier 'uncompressed', using compression off
^C^C
Commands:
blockMesh
You may ask "Why did you include createTime.H only in process 0?" The reason is when I remove the if statement, the program threw bunch of trace that I did not understand:
Source code:
    argList::addNote
    argList::addOption
        "decomposeParDict",
        "file",
    Pout << "Hello from process " << UPstream::myProcNo() << endl;
    return 0;
Output:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
--> FOAM Warning :
[dogukan:06483] *** An error occurred in MPI_Recv
[dogukan:06483] *** reported by process [1006436353,2]
[dogukan:06483] *** on communicator MPI_COMM_WORLD
[dogukan:06483] *** MPI_ERR_TRUNCATE: message truncated
[dogukan:06483] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[dogukan:06483] ***    and potentially your MPI job)
[3] #0  Foam::error::printStack(Foam::Ostream&) at /opt/OpenFOAM-v2106/src/OSspecific/POSIX/printStack/printStack.C:237
[3] #1  Foam::sigSegv::sigHandler(int) at /opt/OpenFOAM-v2106/src/OSspecific/POSIX/signals/sigSegv.C:51
[3] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[3] #3  ? in ~/OpenFOAM/dogukan-v2106/platforms/linux64GccDPInt32Debug/lib/libhydrology.so
[0] #0  Foam::error::printStack(Foam::Ostream&) at /opt/OpenFOAM-v2106/src/OSspecific/POSIX/printStack/printStack.C:237
[0] #1  Foam::sigSegv::sigHandler(int) at /opt/OpenFOAM-v2106/src/OSspecific/POSIX/signals/sigSegv.C:51
[0] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[0] #3  ? in ~/OpenFOAM/dogukan-v2106/platforms/linux64GccDPInt32Debug/lib/libhydrology.so
[1] #0  Foam::error::printStack(Foam::Ostream&) at /opt/OpenFOAM-v2106/src/OSspecific/POSIX/printStack/printStack.C:237
[1] #1  Foam::sigSegv::sigHandler(int) at /opt/OpenFOAM-v2106/src/OSspecific/POSIX/signals/sigSegv.C:51
[1] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[1] #3  Foam::refCount::refCount() in ~/OpenFOAM/dogukan-v2106/platforms/linux64GccDPInt32Debug/bin/parallelDecompose
[1] #4  Foam::function1Base::function1Base(Foam::word const&, Foam::dictionary const&) at /opt/OpenFOAM-v2106/src/OpenFOAM/primitives/functions/Function1/Function1/function1Base.C:47
[1] #5  Foam::Function1<Foam::Tensor<double> >::Function1(Foam::word const&, Foam::dictionary const&)[dogukan:06477] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[dogukan:06477] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
[warn] Epoll MOD(1) on fd 25 failed. Old events were 6; read change was 0 (none); write change was 2 (del); close change was 0 (none): Bad file descriptor
Why do you think that happens?
Thank you.
Old   July 19, 2022, 09:47
Mark Olesen
Start with a simpler case (ie, with really basic BCs) - looks like you have something complex going on with the Function1 creation.
If you try to avoid the problem by only calling a parallel-aware routine like creating Time, you should not be overly surprised that it blocks infinitely. Not any better/worse than trying to call an MPI_Reduce from rank 0 only.
EDIT: don't be surprised or annoyed that I will very likely stop following up on your questions. As I said before, trying to parallelise decomposePar without a deeper understanding of the OpenFOAM internals is not a task that can be recommended. If, however, you are to continue pursuing this course, you should find someone locally to help you.
Old   July 19, 2022, 09:54
Doğukan Teber
At this point, I am just trying to replicate decomposePar and trying to eliminate for loops to replace them with processes for performance improvements. So, I do not know exactly what is going on behind the scenes. May I ask, what does BCs stand for? Also, can you give me extra simple case examples?
Thank you for your fast responses. I appreciate it.
Old   July 19, 2022, 09:55
Doğukan Teber
Okay sir. Thank you for your time.
Old   January 2, 2023, 10:46
Volkan Atar
Volkanatar is on a distinguished road
Source Code:
#include "fvCFD.H"
    argList::addNote
    argList::addOption
        "decomposeParDict",
        "file",
    if (p_no == 0 ) {
    return 0;
Output:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
--> FOAM Warning :
^C^C
Commands:
blockMesh
Source code:
    argList::addNote
    argList::addOption
        "decomposeParDict",
        "file",
    return 0;
Output:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
--> FOAM Warning :
Thank you.
Could you find any solution Dogukan? I'm having the same problem.
Volkanatar is offline   Reply With Quote
decomposepar, mpi, openfoam
[OpenFOAM.com] Install OpenFOAM 3.0.1 on cluster without root access; mpi error Madeinspace OpenFOAM Installation 1 July 4, 2020 15:16
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Pre-Processing 0 April 14, 2008 00:15
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Running, Solving & CFD 0 April 14, 2008 00:04
