July 14, 2022, 12:49 |
Parallelizing decomposePar utility
Doğukan Teber
Rep Power: 4 |
Hello, all.
I am a software engineering student and am pretty novice in terms of OpenFOAM and CFD. I am doing an internship to gain experience in HPC and parallel computation. My responsibility is to develop a utility that does the exact same thing as decomposePar does but in parallel so that the decomposition of meshes is performed as quickly as possible. Also, the initial version will only support simple decomposition method. I know how to handle the parallelization stuff but I cannot understand the structure of a mesh. Since I do not understand a mesh, I do not know how to decompose a mesh. I have been reading the source code of decomposePar to understand how decomposition is done but without comprehending the concept of mesh, the code does not mean too much to me. So my question is how can I decompose a mesh? In addition to that, can you recommend resources to understand the structure of a mesh expect this? Thank you |
July 14, 2022, 18:38 |
Mark Olesen
Rep Power: 40 |
The simplest would be to use "redistributePar -decompose", which sounds much like what you want. If there is something extra you need for it, follow up here or (if you have funding and a project) on develop.openfoam.com
I think you will find understanding the redistributePar code much more difficult than decomposePar. Not a realistic task as an internship at all. BTW: redistributePar has been updated in the latest (OPENFOAM-V2206) release to support point fields and finiteArea fields. |
July 18, 2022, 08:51 |
Doğukan Teber
Rep Power: 4 |
Thank you for your reply olesen and sorry for the late response. I wanted to be sure before I wrote this post.
I have talked to my mentor, who said that he had already tried other options but on each try, the performance did not make so much difference compared to decomposePar. That is why we are developing this utility. I am open to other suggestions though. |
July 18, 2022, 10:22 |
Mark Olesen
Rep Power: 40 |
I noticed that you didn't mention which version of OpenFOAM you were using. See, for example, (https://develop.openfoam.com/Develop.../-/issues/1211) - which avoids triggering costly intermediate topological rebuilds. Might make sense to field through https://www.openfoam.com/products-se...ftware-support as a project to diagnose where your bottlenecks arise and what can be done about them. As I already mentioned, this is quite unrealistic as a project for an intern without prior and extensive OpenFOAM knowledge.
decomposepar, mesh, parallel decomposition |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 17:47 |
DecomposePar utility | hsing | OpenFOAM Running, Solving & CFD | 11 | January 19, 2015 05:09 |
[Other] How to create uneven load for the processors using decomposePar utility. | shinde.gopal | OpenFOAM Meshing & Mesh Conversion | 1 | May 24, 2014 09:49 |
About the problem of decomposePar utility | zou_mo | OpenFOAM Running, Solving & CFD | 3 | July 27, 2005 19:18 |
