Update on how to implement the temperature equation in interPhaseChangeFoam
Old   June 25, 2022, 10:57
Post Update on how to implement the temperature equation in interPhaseChangeFoam
JD_PM is on a distinguished road
Yesterday I posted about the issues I was having while implementing a simple version of the temperature equation in interPhaseChangeFoam (Implementing the temperature equation in interPhaseChangeFoam (OpenFOAM 8 version)) and advanced a bit.
All I did was changing the name of the original solver to interPhaseChangeThermalFoam, change the name of the file phaseChangetwoPhaseMixture to twoPhaseMixtureThermo and modifying the following files
interPhaseChangeThermalFoam.C
#include "fvCFD.H"
#include "dynamicFvMesh.H"
#include "CMULES.H"
#include "subCycle.H"
#include "interfaceProperties.H"
#include "phaseChangeTwoPhaseMixture.H"
#include "kinematicMomentumTransportModel.H"
#include "pimpleControl.H"
#include "fvOptions.H"
#include "CorrectPhi.H"
int main(int argc, char *argv[])
    #include "postProcess.H"
    #include "setRootCaseLists.H"
    #include "createTime.H"
    #include "createDynamicFvMesh.H"
    #include "createDyMControls.H"
    #include "initContinuityErrs.H"
    #include "createFields.H"
    #include "initCorrectPhi.H"
    #include "createUfIfPresent.H"
    turbulence->validate();
    #include "CourantNo.H"
    #include "setInitialDeltaT.H"
    Info<< "\nStarting time loop\n" << endl;
    while (pimple.run(runTime))
        #include "readDyMControls.H"
        // Store divU from the previous mesh so that it can be mapped
        // and used in correctPhi to ensure the corrected phi has the
        // same divergence
        volScalarField divU("divU0", fvc::div(fvc::absolute(phi, U)));
        #include "alphaCourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
            if (pimple.firstPimpleIter() || moveMeshOuterCorrectors)
                mesh.update();
                if (mesh.changing())
                    gh = (g & mesh.C()) - ghRef;
                    ghf = (g & mesh.Cf()) - ghRef;
                    if (correctPhi)
                        // Calculate absolute flux
                        // from the mapped surface velocity
                        phi = mesh.Sf() & Uf();
                        #include "correctPhi.H"
                        // Make the flux relative to the mesh motion
                        fvc::makeRelative(phi, U);
                    mixture.correct();
                    if (checkMeshCourantNo)
                        #include "meshCourantNo.H"
            divU = fvc::div(fvc::absolute(phi, U));
            surfaceScalarField rhoPhi
                IOobject
                    "rhoPhi",
                    runTime.timeName(),
                    mesh
                mesh,
                dimensionedScalar(dimMass/dimTime, 0)
            #include "alphaControls.H"
            #include "alphaEqnSubCycle.H"
            mixture.correct();
            #include "UEqn.H"
			#include "TEqn.H"
            // --- Pressure corrector loop
            while (pimple.correct())
                #include "pEqn.H"
            if (pimple.turbCorr())
                turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
createFields.H
Info<< "Reading field p_rgh\n" << endl;
volScalarField p_rgh
    IOobject
        "p_rgh",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
Info<< "Reading field U\n" << endl;
volVectorField U
    IOobject
        "U",
        runTime.timeName(),
        mesh,
    mesh
//scalar field for the temperature
Info<< "Reading field T\n" << endl;
volVectorField T
    IOobject
        "T",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ, // Must read T from the latest time directory
        IOobject::AUTO_WRITE // Data will be written according to controlDict
    mesh
#include "createPhi.H"
Info<< "Creating phaseChangeTwoPhaseMixture\n" << endl;
autoPtr<phaseChangeTwoPhaseMixture> mixturePtr
    phaseChangeTwoPhaseMixture::New(U, phi)
phaseChangeTwoPhaseMixture& mixture = mixturePtr();
volScalarField& alpha1(mixture.alpha1());
volScalarField& alpha2(mixture.alpha2());
const dimensionedScalar& rho1 = mixture.rho1();
const dimensionedScalar& rho2 = mixture.rho2();
// Need to store rho for ddt(rho, U)
volScalarField rho
    IOobject
        "rho",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT
    alpha1*rho1 + alpha2*rho2
rho.oldTime();
// Construct incompressible turbulence model
autoPtr<incompressible::momentumTransportModel> turbulence
    incompressible::momentumTransportModel::New(U, phi, mixture)
dimensionedScalar DT
	"DT",
	mixture.lookup("DT")
#include "readGravitationalAcceleration.H"
#include "readhRef.H"
#include "gh.H"
volScalarField p
    IOobject
        "p",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    p_rgh + rho*gh
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell
    p,
    p_rgh,
    pimple.dict(),
    pRefCell,
    pRefValue
if (p_rgh.needReference())
    p += dimensionedScalar
        "p",
        p.dimensions(),
        pRefValue - getRefCellValue(p, pRefCell)
    p_rgh = p - rho*gh;
mesh.setFluxRequired(p_rgh.name());
mesh.setFluxRequired(alpha1.name());
#include "createFvOptions.H"
TEqn.H
fvScalarMatrix TEqn
        fvm::ddt(T) + fvm::div(phi,T) == fvm::laplacian(DT, T)
    TEqn.relax();
    TEqn.solve();
interPhaseChangeThermalFoam/Make/files
EXE = $(FOAM_USER_APPBIN)/interPhaseChangeThermalFoam
interPhaseChangeThermalFoam/Make/options
EXE_INC = \
    -I. \
    -I$(LIB_SRC)/transportModels/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/incompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
    -IphaseChangeTwoPhaseMixtures/lnInclude \
    -ItwoPhaseMixtureThermo/lnInclude \
    -I$(LIB_SRC)/MomentumTransportModels/momentumTransportModels/lnInclude \
    -I$(LIB_SRC)/MomentumTransportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/dynamicFvMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lphaseChangeTwoPhaseMixtures \
    -ltwoPhaseMixture \
    -lmyTwoPhaseMixtureThermo \
    -linterfaceProperties \
    -ltwoPhaseProperties \
    -lincompressibleTransportModels \
    -lmomentumTransportModels \
    -lincompressibleMomentumTransportModels \
    -lfiniteVolume \
    -ldynamicFvMesh \
    -ltopoChangerFvMesh \
    -lfvOptions \
    -lmeshTools
interPhaseChangeThermalFoam/twoPhaseMixtureThermo/Make/files
twoPhaseMixtureThermo/phaseChangeTwoPhaseMixture.C
twoPhaseMixtureThermo/phaseChangeTwoPhaseMixtureNew.C
Kunz/Kunz.C
Merkle/Merkle.C
SchnerrSauer/SchnerrSauer.C
ZGB/ZGB.C
LIB = $(FOAM_USER_LIBBIN)/libmyTwoPhaseMixtureThermo
interPhaseChangeThermalFoam/twoPhaseMixtureThermo/Make/options
EXE_INC = \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
LIB_LIBS = \
    -lfluidThermophysicalModels \
    -limmiscibleIncompressibleTwoPhaseMixture \
    -lspecie \
    -ltwoPhaseMixture \
    -lfiniteVolume
The rest of files stay essentially the same than the interPhaseChangeFoam's solver.
I get the following error when I compile the solver
TEqn.H: In function ‘int main(int, char**)’:
TEqn.H:7:5: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >)’
    7 |     );
In file included from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.H:1058,
                 from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/ddtScheme.C:29,
                 from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/ddtScheme.H:357,
                 from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvcDdt.H:250,
                 from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvc.H:44,
                 from /software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from interPhaseChangeThermalFoam.C:44:
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:405:1: note: candidate: ‘Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = double]’
  405 | Foam::fvMatrix<Type>::fvMatrix
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:405:1: note:   candidate expects 2 arguments, 1 provided
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:351:1: note: candidate: ‘Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double]’
  351 | Foam::fvMatrix<Type>::fvMatrix(const tmp<fvMatrix<Type>>& tfvm)
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:351:59: note:   no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::tmp<Foam::fvMatrix<double> >&’
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:322:1: note: candidate: ‘Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = double]’
  322 | Foam::fvMatrix<Type>::fvMatrix(const fvMatrix<Type>& fvm)
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:322:54: note:   no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::fvMatrix<double>&’
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:267:1: note: candidate: ‘Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = double]’
  267 | Foam::fvMatrix<Type>::fvMatrix
/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude/fvMatrix.C:267:1: note:   candidate expects 2 arguments, 1 provided
make: *** [/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/wmake/rules/General/transform:26: Make/linux64GccDPInt64Opt/interPhaseChangeThermalFoam.o] Error 1
So it seems that the problem is with the temperature equation file.
Any feedback is appreciated.
JD_PM is offline   Reply With Quote
Old   June 25, 2022, 12:37
Post
I changed the TEqn.H file as follows
solve
I compiled the solver and it yielded a new error:
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
    wmakeLnInclude error: base directory phaseChangeTwoPhaseMixtures/ does not exist
Making dependency list for source file interPhaseChangeThermalFoam.C
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I. -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/transportModels/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/twoPhaseMixture/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/interfaceProperties/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/incompressibleTwoPhaseMixture/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -IphaseChangeTwoPhaseMixtures/lnInclude -ItwoPhaseMixtureThermo/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/MomentumTransportModels/incompressible/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/dynamicFvMesh/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/OpenFOAM/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/OSspecific/POSIX/lnInclude   -fPIC -c interPhaseChangeThermalFoam.C -o Make/linux64GccDPInt64Opt/interPhaseChangeThermalFoam.o
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I. -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/transportModels/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/twoPhaseMixture/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/interfaceProperties/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/incompressibleTwoPhaseMixture/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -IphaseChangeTwoPhaseMixtures/lnInclude -ItwoPhaseMixtureThermo/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/MomentumTransportModels/incompressible/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/finiteVolume/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/dynamicFvMesh/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/OpenFOAM/lnInclude -I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/interPhaseChangeThermalFoam.o -L/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/platforms/linux64GccDPInt64Opt/lib \
    -L/students/2021/jrodriguez/OpenFOAM/jrodriguez-8/platforms/linux64GccDPInt64Opt/lib -lphaseChangeTwoPhaseMixtures -ltwoPhaseMixture -lmyTwoPhaseMixtureThermo -linterfaceProperties -ltwoPhaseProperties -lincompressibleTransportModels -lmomentumTransportModels -lincompressibleMomentumTransportModels -lfiniteVolume -ldynamicFvMesh -ltopoChangerFvMesh -lfvOptions -lmeshTools -lOpenFOAM -ldl  \
     -lm -o /students/2021/jrodriguez/OpenFOAM/jrodriguez-8/platforms/linux64GccDPInt64Opt/bin/interPhaseChangeThermalFoam
I decided to run it anyway and see if it worked.
I used a tutorial case (cavitatingBullet) and included T boundary condition
T
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           $internalField;
    walls
        type            symmetry;
    bullet
        type            zeroGradient;
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default             Euler;
interpolationSchemes
    default             linear;
divSchemes
    default             none;
    div(rhoPhi,U)       Gauss linearUpwind grad(U);
    div(phi,T)          Gauss linearUpwind grad(T);
    div(phi,omega)      Gauss linearUpwind grad(omega);
    div(phi,k)          Gauss linearUpwind grad(k);
    div(phi,alpha)  Gauss interfaceCompression vanLeer 1;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
gradSchemes
    default             Gauss linear;
laplacianSchemes
    default             Gauss linear limited corrected 0.5;
snGradSchemes
    default             limited corrected 0.5;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    "alpha.N2.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        MULESCorr       yes;
        nLimiterIter    5;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
        maxIter         10;
    "U.*"
        tolerance       1e-6;
        relTol          0;
    T
        tolerance       1e-6;
        relTol          0;
    p_rgh
        solver          GAMG;
        tolerance       1e-8;
        relTol          0.1;
        smoother        DICGaussSeidel;
        maxIter         50;
    p_rghFinal
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-6;
            relTol          0;
            nVcycles        2;
        tolerance       1e-7;
        relTol          0;
        maxIter         50;
    "pcorr.*"
        $p_rgh;
        relTol          0;
    Phi
        $p_rgh;
        relTol          0;
potentialFlow
    nNonOrthogonalCorrectors   3;
PIMPLE
    momentumPredictor           no;
    nOuterCorrectors            1;
    nCorrectors                 3;
    nNonOrthogonalCorrectors    0;
relaxationFactors
    equations
        ".*"                    1;
When I run it I get the following error
[1] --> FOAM FATAL IO ERROR:
[1] unexpected class name volScalarField expected volVectorField
    while reading object T
[1]
[1] file: /nobackup/st/jrodriguez/cavitatingBulletThermoTEST/processor1/0/T at line 15.
[1]
[1]     From function Foam::Istream& Foam::regIOobject::readStream(const Foam::word&, bool)
[1]     in file db/regIOobject/regIOobjectRead.C at line 172.
[1]
FOAM parallel run exiting
Old   June 28, 2022, 11:45
The mistake was in the createFields file. Temperature is of course a scalar field.
volScalarField T
    IOobject
        "T",
        runTime.timeName(),
        mesh,
    mesh
Now it compiles OK.
Old   July 8, 2022, 02:45
Default Temperature for phases
Prithvi
prinux is on a distinguished road
Hi JD_PM,
Thanks for these useful information. I just wanted to know: Are you able to define temperatures for the different phases with this implementation? For example, say your phases are air and water. Are you able to define T.air and T.water initial conditions in the 0 folder of your case files?
Thanks,
Prithvi
prinux is offline   Reply With Quote
Old   July 8, 2022, 03:26
überschwupper is on a distinguished road
Originally Posted by prinux View Post
Hi JD_PM,
Thanks,
Prithvi
You can do it by using the thermo libraries for example. But then you have to rewrite your twoPhaseMixture file otherwise you will have redundancies.
überschwupper is offline   Reply With Quote
Old   July 8, 2022, 03:39
Prithvi
Hi überschwupper,
I have copied a library named "twoPhaseMixtureThermo" from compressibleInterFoam to my custom interPhaseChangeFoam directory. Is this what you are talking about? I'm using this because I had observed in the compressibleInterFoam tutorial cases that each phase has it's own T.phase file.
Right now, I have copied this library and I am removing the thermodynamic properties from the libraries that I do not need. Am I going in the right direction?
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Temperature Equation in interFoam claudiocor OpenFOAM Running, Solving & CFD 2 April 30, 2018 10:48
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 14:15
how to implement this kind of equation keishawillstone OpenFOAM Running, Solving & CFD 2 August 11, 2009 07:01
Transport Equation for temperature variance ameya OpenFOAM Running, Solving & CFD 0 December 5, 2008 02:16
