customize semiImplicitSource
Old   June 25, 2022, 10:46
Default customize semiImplicitSource
chen112p's Avatar
Junting Chen
chen112p is on a distinguished road
Hello, I am trying to add some custom features to semiImplicitSource library. However, without touching the core parts of the code, FOAM couldnt read the new library for some reasons. Hope someone can help me with this.
So I first copied the source code (the entire src/fvOptions to be safe) to somewhere other than $FOAM_SRC. Then I changed $FOAM_LIBBIN in Make/files to $FOAM_USER_LIBBIN and removed the unnecessary items in files. Then I changed type name in SemiImplicitSource.H to something other than "SemiImplicitSource" (ie. jtSemiImplicitSource) so when I call this library I know I'm not calling the original one.
Compile went ok (because technically I didnt change anything), but when adding the new type to fvOptions, FOAM tells me the new type name Im using (ie. scalarjtSemiImplicitSource) is not found.
Can someone tell me what is missing here?
jt
chen112p is offline   Reply With Quote
Old   June 27, 2022, 05:45
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
If your library loads properly, it sounds like you forgot to register your sources.
Eg,
makeFvOption(SemiImplicitSource, scalar);
olesen is offline   Reply With Quote
Old   December 7, 2024, 08:41
likun
ouqiyo is on a distinguished road
Hello, I have recently encountered this problem, also just change SemiImplicitSource to mySemiImplicitSource in the file name and SemiImplicitSource to mySemiImplicitSource in the content of the file, it compiles successfully, but when using it I can't load the library. It compiles successfully, but when I use it, I can't load the library in fvoptons, besides, the code makeFvOption(SemiImplicitSource, scalar); exists in the original file, may I know how else to solve it?
ouqiyo is offline   Reply With Quote
Customize the Prandtl number in the k-epsilon mode ClydeL FLUENT 5 November 20, 2021 23:11
fvOptions: Time dependent semiImplicitSource uosilos OpenFOAM Running, Solving & CFD 1 July 2, 2021 05:12
Modify SemiImplicitSource for time varying source ksgr OpenFOAM Running, Solving & CFD 0 August 20, 2020 11:21
how to customize the initial velocity and temperature field? gdtiaozi FLOW-3D 1 December 3, 2013 08:13
Can I Customize Fluent Environment venugopal FLUENT 0 June 16, 2004 13:15
