[Expressions - swak4foam] troubles for custom boundary condition
Old   June 7, 2022, 11:49
Default [Expressions - swak4foam] troubles for custom boundary condition
Eric Segalerba
EricS is on a distinguished road
Hi everybody,
I'm trying to implement a time dependent boundary condition.
I'm using Expressions that should be close to swak4foam but I can't really figure out how is the synthax.
This is the boundary condition I wrote
throat
     type            flowRateOutletVelocity;
     volumetricFlowRate    uniform -2.67e-04;
     type            exprFixedValue;
     variables
         "CPI = 0.01"
         "p_throat{throat} = weightAverage(p.t())"
     valueExpr
         CPI / p_throat
     value uniform (0 0 0);
My doubts are the following:
1. surely I wrote in the wrong way the type but I can't figure out how to code a boundary condition which computes the flowrate
2. how can I make the code read the patch pressure runtime? Is .t sufficient?
Thank you in advance!
EricS is offline   Reply With Quote
Old   June 14, 2022, 10:07
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I haven't checked much (or anything) of what you are actually doing, but you should note that for a flowRateOutletVelocity boundary condition, the "massFlowRate" or "volumetricFlowRate" is already a Function1, which means that you can also specify an expression for that.
I don't see a good reason why you would instead want to re-implement things using an exprFixedValue - IMO It makes more sense to leverage the existing boundary condition.
olesen is offline   Reply With Quote
expressions, openfoam v2106, programming, swak4foam
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
Radiation interface hinca CFX 15 January 26, 2014 18:11
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
