May 3, 2022, 11:16 |
Computing the heat flux vector in OpenFoam
Nikos Vasileiadis
Rep Power: 4 |
Hello to everyone,
I am new to OpenFoam. I have a simple laminar simulation and I want to compute and output the heat flux vector (thermalConductivity*grad(T)) for all the cells of my domain. I have found that you can get the heat flux normal to the domain boundaries using the wallHeatFlux utility. However, I cannot find anything helpful on the heat flux vector in a cell. I would be grateful if anyone can provide a solution or point me towards one. Thanks for any help. |
July 9, 2022, 19:22 |
Joachim Herb
Rep Power: 22 |
I guess you use paraview? Have you loaded the also the paches. The heat flux field should be defined on the walls (and in the cells of the internal field).
heat flux in a cell, heat transfer |
Simulating constant heat flux value at solid-solid boundary | Y27 | STAR-CCM+ | 6 | September 8, 2020 09:56 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 11:45 |
Calculating heat flux in OpenFOAM | eretief | OpenFOAM Programming & Development | 1 | May 19, 2014 10:15 |
