How could I access temperature T and density rho from a turbulenceModel library?
Old   April 23, 2022, 16:11
Default How could I access temperature T and density rho from a turbulenceModel library?
Anuar Giménez
anuargimenez is on a distinguished road
Hello Foamers,
I am trying to add a temperature dependent viscosity model to use it in a compressible solver (rhoSimpleFoam). For that, I need to modify the CrossPowerLaw model in src/TurbulenceModels/turbulenceModels/laminar/generalizedNewtonian/generalizedNewtonianViscosityModels/CrossPowerLaw and add a Temperature and Density dependent expression.
I tried to acces theese variables with:
const volScalarField& T = U_.mesh().lookupObject<volScalarField>("T");
const volScalarField& rho = U_.mesh().lookupObject<volScalarField>("rho");
But when I compile i get this error:
CrossWLF.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::laminarModels::generalizedNewtonianViscosityModels::CrossWLF::nu(const volScalarField&, const volScalarField&) const’:
CrossWLF.C:119:28: error: ‘U_’ was not declared in this scope; did you mean ‘m_’?
  119 |  const volScalarField& T = U_.mesh().lookupObject<volScalarField>("T");
      |                            m_
CrossWLF.C:119:65: error: expected primary-expression before ‘>’ token
Any advice would be very helpfull.
Thank you very much in advance for your help!!
anuargimenez is offline   Reply With Quote
openfoam
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
