hari charan
Rep Power: 4 ![]() |
Hello guys,
I am trying to implement energy equation and mass transfer model in interPhaseChangeFoam. I implemented mass transfer model, it compiled well.But when I am compiling solver I am getting the following error. Code:
/home/hari/OpenFOAM/hari-8/applications/solvers/multiphase/interPhaseChangeFoam_2/createFields.H:50: undefined reference to `Foam::phaseChangeTwoPhaseMixture::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)' /usr/bin/ld.bfd: /home/hari/OpenFOAM/hari-8/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleTwoPhaseThermalMixture.so: undefined reference to `Foam::conductivityModel::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&)' collect2: error: ld returned 1 exit status My options file is like this. Code:
EXE_INC = \ -I. \ -I$(LIB_SRC)/transportModels/lnInclude \ -I$(LIB_SRC)/twoPhaseModels/twoPhaseMixture/lnInclude \ -I$(LIB_SRC)/twoPhaseModels/interfaceProperties/lnInclude \ -I$(LIB_SRC)/twoPhaseModels/incompressibleTwoPhaseMixture/lnInclude \ -I$(LIB_SRC)/twoPhaseModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \ -I$(WM_PROJECT_USER_DIR)/src/twoPhaseModels/myIncompressibleTwoPhaseThermalMixture/lnInclude \ -I$(LIB_SRC)/MomentumTransportModels/momentumTransportModels/lnInclude \ -I$(LIB_SRC)/MomentumTransportModels/incompressible/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/dynamicFvMesh/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -IphaseChangeTwoPhaseMixtures/lnInclude \ -I$(WM_PROJECT_USER_DIR)/src/transportModels/conductivityModels/lnInclude \ -DFULLDEBUG -g -O0 EXE_LIBS = \ -lphaseChangeTwoPhaseMixtures \ -ltwoPhaseMixture \ -linterfaceProperties \ -ltwoPhaseProperties \ -lincompressibleTransportModels \ -lmomentumTransportModels \ -lincompressibleMomentumTransportModels \ -lfiniteVolume \ -ldynamicFvMesh \ -ltopoChangerFvMesh \ -lfvOptions \ -lmeshTools \ -L/home/hari/OpenFOAM/hari-8/platforms/linux64GccDPInt32Opt/lib \ -lmyIncompressibleTwoPhaseThermalMixture |
#2 | |
zink
Rep Power: 10 ![]() |
The error means that your compilation does not link with Openfoam SRC. Can you elaborate a bit so that i can comment further? |
hari charan
In SRC user directory I implemented a mixture model called myIncompressibleTwoPhaseThermalMixture. This is in src/twoPhaseModels.
And in SRC/transportModels I have conductivity models and fourier model. The source code in conductivity model is like selecting fourier model for evaluating thermal conductivity. I compiled both transportModels and twoPhaseModels with out error. But when I link them to solver I got the error I mentioned above. The compiled files are in platforms/lib folder. I gave correct path like $FOAM_USER_LIBBIN to lib folder(i.e compiled directored which is lib folder in platforms folder) Thanks in advance |
interphasechangefoam, openfoam, openfoam8 |
Adding Libraries to OpenFOAM | MCrossover97 | OpenFOAM Programming & Development | 10 | February 23, 2024 02:34 |
can not complie fluentDataToFoam in OF2.1.1 | hewei | OpenFOAM Pre-Processing | 20 | September 8, 2018 09:19 |
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
compile error about FJMPI | chiven | OpenFOAM Installation | 11 | March 31, 2010 06:27 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
