codeStream to update b.c.
Old   April 21, 2022, 12:56
Post codeStream to update b.c.
Eric Segalerba
EricS is on a distinguished road
Hi Foamers!
I'm struggling with a problem which consists in implementing a boundary condtion that changes in time.
I tried to solve this problem using codeStream but, so far, I only ended up with errors and, not being a skillful programmer, I'm stuck here ..
The boundary condition that I'm trying to implement should do what it follows:
1. I impose a value of power (called CPI) which is: CPI = mass_flow_rate * delta_P;
2. I estimate a value of delta_P which becomes delta_P^(1);
3. I compute the resulting mass_flow_rate as: mass_flow_rate^(2) = CPI/delta_P^(1);
4. I use mass_flow_rate^(2) as a boundary condition and I compute delta_P^(2) for that timestep;
5. then I use delta_P^(2) to compute mass_flow_rate^(3) and so on...
I can summarize as mass_flow_rate^(i+1) = CPI/delta_P^(i)
So far I wrote:
throat
    type            flowRateOutletVelocity;
    volumetricFlowRate     #codeStream
            codeInclude
                #include "fvCFD.H"
            codeOptions
                -I$(LIB_SRC)/finiteVolume/lnInclude \
                -I$(LIB_SRC)/meshTools/lnInclude
            //libs needed to visualize BC in paraview
            codeLibs
            -lmeshTools \
            -lfiniteVolume
            code
        /* CYCLE EXPLAINED
        input = CPI = massFlowRate * deltaP
        1. massFlowRate = CPI / deltaP;
        2. compute first timestep with the massFlowRate just calculated;
        3. compute deltaP (which is deltaP = p_amb - p_throat = 0 - p_throat = -p_throat);
        4. correct massFlowRate with the new value of p_throat;
        5. keep iterating...
            massFlowRate^(i+1) = - CPI / p_throat^(i)
                const IOdictionary& d = static_cast<const IOdictionary&>
                    dict.parent().parent()
                const fvMesh& mesh = refCast<const fvMesh>(d.db());
                const label id = mesh.boundary().findPatchID("throat");
                const fvPatch& patch = mesh.boundary()[id];
                vectorField U(patch.size(), vector(0, 0, 0));
        const CPI = 500;
                const surfaceVectorField& p = patch().lookupObject("p");
        const massFlowRate = -CPI/average(p)
                writeEntry(os,"", massFlowRate);
    value            uniform (0 0 0);
but it's only giving me errors...
any tips to make it work?
Thank you in advance!!!
EricS is offline   Reply With Quote
How to get current time using codeStream in b.c. CarlesCQL OpenFOAM Pre-Processing 1 July 14, 2022 07:09
B.C. CodeStream does not repeat during runtime sjafarik OpenFOAM Programming & Development 3 March 4, 2022 02:48
CodeStream Error EzgiCFD OpenFOAM Running, Solving & CFD 0 January 31, 2022 14:38
PROBLEMS DEFINING A LIST USING #CODESTREAM !! Help please !! angatri_14 OpenFOAM Programming & Development 1 August 21, 2020 18:16
How to get current time using codeStream in b.c. CarlesCQL OpenFOAM Programming & Development 0 February 17, 2016 12:02
