Are there any input streams from standard console? |
April 14, 2022, 06:36 |
Rep Power: 6 |
Dear foamers,
Are there any input stream wrappers for reading from standard input stream just like Info or Pout for information output? I didn't encounter such classes till now. I raised this post just out of curiosity. I would be grateful if you have any idea about this question. |
April 20, 2022, 13:19 |
#2 | |
Mark Olesen
Rep Power: 40 |
The `Sin` stream ? (defined in IOstreams.H). Note however with Info, it isn't actually a regular direct stream but a messageStream, which is how it also handles suppressing output on non-master processes. |
April 21, 2022, 04:42 |
Rep Power: 6 |
Hi Mark, Thanks for your reply. It seems that OpenFOAM doesn't use the 'Sin' stream directly. I'll have a close look at the class. Thank you again.
Standard vs Actual Inlet Velocity as BC | rajcoep.88 | Main CFD Forum | 3 | February 8, 2016 09:47 |
cooler heat input | DineshramBalaji | FLUENT | 4 | May 17, 2014 09:04 |
reading profiles as input parameters? | alechan | Fluent UDF and Scheme Programming | 0 | March 14, 2014 06:10 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 11:45 |
ANSYS ICEM CFD: lsdyna input file creation problem | Evan | CFX | 0 | June 15, 2006 14:12 |
