Dimensioned scalar to double
Old   April 12, 2022, 18:21
Exclamation Dimensioned scalar to double
Mona
Monaglp is on a distinguished road
Hi, I have this error
no matching function for call to ‘Foam::dimensioned<double>::dimensioned(Foam::dime nsionSet&, double)’
dimensionedScalar(s_.dimensions(), 0.0)
can anyone help me to fix it?
Monaglp is offline   Reply With Quote
Old   April 13, 2022, 00:13
Voulet is on a distinguished road
Try to use myDimensionedVariable.value() instead of myDimensionedVariable.
« Debugging is what CFD is about. 5 minutes to modify your code, 5 months to find why it does not work anymore. »
Voulet is offline   Reply With Quote
Old   April 13, 2022, 16:37
Mona
can you explain more please?
Old   April 14, 2022, 00:02
Can you post your code few lines above this error and few lines bellow ?
Old   May 2, 2022, 18:20
Mona
I solved the problem.
dimensioned, dimensionedscalar
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
