Transform volSymmTensorField to volTensorField |
Sean
Rep Power: 4 ![]() |
Hi!
I'm working on a customized turbulence model in OF7. Somewhere in the calculations I have to add volSymmTensorField and volTensorField which I can't figure out. On the forum I've seen one post about this, where it was suggested to multiply the volSymmTensorfield with tensor(1, 0, 0, 0, 1, 0, 0, 0, 1) if the computational overhead was not that important, which it isn't since they are very small 2D cases. See below: Code:
tauij_ = -2*nut() * S & tensor(1, 0, 0, 0, 1, 0, 0, 0, 1); The error message is: Code:
no match for ‘operator=’ (operand types are ‘Foam::volTensorField {aka Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>}’ and‘Foam::tmp<Foam::DimensionedField<Foam::SymmTensor<double>, Foam::volMesh> >’) tauij_ = -2*nut() * S & I Code:
S.component(1) = S_symm.component(1); S.component(2) = S_symm.component(2); S.component(3) = S_symm.component(3); S.component(4) = S_symm.component(2); S.component(5) = S_symm.component(4); S.component(6) = S_symm.component(5); S.component(7) = S_symm.component(3); S.component(8) = S_symm.component(5); S.component(9) = S_symm.component(6); PS: these are the same right? Code:
I = tensor(1, 0, 0, 0, 1, 0, 0, 0, 1) |
Agustín Villa
Rep Power: 15 ![]() |
could you provide the equation you want to add in OpenFOAM? Maybe it is possible to find a way to implement it. |
programing, transformation tensor, volsymmtensorfield, voltensorfield |
eigenValues of volTensorField | xuegy | OpenFOAM Programming & Development | 8 | February 26, 2021 16:46 |
create volTensorField in rhoCentralFoam | SKLee | OpenFOAM Running, Solving & CFD | 1 | December 30, 2012 03:36 |
flux limiter involving tensor : How to use fvc::flux() with volTensorField ? | Cyp | OpenFOAM Programming & Development | 2 | January 21, 2011 04:36 |
Transformation of volSymmTensorField to volTensorField | svens | OpenFOAM | 2 | November 19, 2009 05:47 |
Question on Hilbert Transform | Wen Long | Main CFD Forum | 1 | April 29, 2004 05:58 |
