Which transformPoints() function is called when the mesh is rotating? |
April 5, 2022, 08:11 |
dzs
Rep Power: 7 |
Hi foamers, this transformPoints() function is called when you are simulating for a rotating mesh case, which is the simulation I'm doing now.
My question initiated from the source code: solidBodyMotionSolver.C, in member function curPoints() at line 157. (Find it via link 1). You may easily find that there are 2 transformPoints() functions are used, one is for mesh is not rotating, and another is used when mesh is rotating. So my question is which transformPoints() function, defined in transformField.C at line 97 and 109, is used when mesh is not rotating (/and rotating)? (Find it via link 2). link 1:https://cpp.openfoam.org/v7/solidBod...8C_source.html link 2:https://cpp.openfoam.org/v7/transfor...ce.html#l00070 Thanks in helping! zs |
dynamic mesh; |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
