Compilation error with fvModels.correct()
Old   April 1, 2022, 14:56
Question Compilation error with fvModels.correct()
Robert Castilla
rcastilla is on a distinguished road
I have been trying to port the humidityRhoThermo library by Holtzmann to OF9. You can check the branch in rclUPC@github. The problem is that it is not working properly and I suspect that it is because transport is not solved. In OF9 the fvOptions has been replaced by fvModels and fvConstraints. When I try to make fvModels.correct instead of fvOptions.correct it gives an error about converting Foam::fvModels to const Foam:fvModels. Probably it is very simple, but I am not an expert in C++ and I am unable to see the solution.
Hope somebody can help me with that.
Greetings!
Robert
rcastilla is offline   Reply With Quote
fvmodels
[foam-extend.org] foam-extend-3.2 compilation on windows kirmaks OpenFOAM Installation 7 December 3, 2019 21:20
[OpenFOAM.org] Compilation Error with OpenFOAM-5.x using Intel Compilers aow OpenFOAM Installation 4 April 25, 2019 17:17
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit Sargam05 OpenFOAM Installation 13 March 22, 2014 06:21
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 06:56
Compilation Error.... Arnab Siemens 4 September 12, 2004 16:54
