Make a particles list in MomentumCloud
Old   March 11, 2022, 14:38
Default Make a particles list in MomentumCloud
Yves Robert
yv3s95 is on a distinguished road
I would like to make a list of parcels in MomentumCloud objects.
Basically, I want to populate a list (DynamicList) of parcels, which is stored for the whole iteration (injection of new parcels and cloud motion). Just for context, the list should contain parcels that are below a certain Zmin.
I am quite new to OpenFOAM development.
So first, how to create a new field in momentum clouds? This field should be a DynamicList of parcels.
Then, how to populate the list?
Here is what I tried to do.
In MomentumCloud.H, I added
void populate_parcels_of_interest(const double);
inline DynamicList<parcelType*> parcels_of_interest();
DynamicList<parcelType*> parcels_of_interest_;
In MomentumCloud.C, I added:
parcels_of_interest_(DynamicList<parcelType*>(0)),
in the constructor
template<class CloudType>
void Foam::MomentumCloud<CloudType>::populate_parcels_of_interest
    const scalar Z_min
    DynamicList<parcelType*>& parcels_of_interest = parcels_of_interest_;
    int i = 0;
    forAllConstIter(typename MomentumCloud<CloudType>, *this, pIter)
        const parcelType p = pIter();
        scalar z = p.position().z();
        Info << "Pos: " << p.position() << nl;
        if (z < Z_min)
            parcels_of_interest.append(&p);
            i ++;
            int j = 0;
            while  (j < i)
                Info << "\tPos " << j << ": " << parcels_of_interest[j]->position() << nl;
                j++;
    forAll(parcels_of_interest, i)
        parcelType p = *parcels_of_interest[i];
        Info << i << "-> Z_min: " << Z_min << " Z: " << z << " test: " << (z >= Z_min) << nl;
When I run the code for 1 step and look at the output (4 parcels injected):
Pos: (0.241657 -0.250083 0.395233)
        Pos 0: (0.241657 -0.250083 0.395233)
Pos: (-0.327668 -0.248501 0.42311)
        Pos 0: (-0.327668 -0.248501 0.42311)
        Pos 1: (-0.327668 -0.248501 0.42311)
Pos: (-0.49028 0.00792265 0.43253)
        Pos 0: (-0.49028 0.00792265 0.43253)
        Pos 1: (-0.49028 0.00792265 0.43253)
        Pos 2: (-0.49028 0.00792265 0.43253)
Pos: (-0.346966 -0.0428658 0.428971)
        Pos 0: (-0.346966 -0.0428658 0.428971)
        Pos 1: (-0.346966 -0.0428658 0.428971)
        Pos 2: (-0.346966 -0.0428658 0.428971)
        Pos 3: (-0.346966 -0.0428658 0.428971)
0-> Z_min: 1e+30 Z: 0.428971 test: 0
1-> Z_min: 1e+30 Z: 0.428971 test: 0
2-> Z_min: 1e+30 Z: 0.428971 test: 0
3-> Z_min: 1e+30 Z: 0.428971 test: 0
It seems like the element I add to the list is getting updated every time, instead of storing the parcel of interest.
I would greatly appreciate help on this matter, as I am really stuck on this problem to go forward in my project.
Thank you.
yv3s95 is offline   Reply With Quote
Old   March 12, 2022, 04:37
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Since you have a DynamicList of pointers to your "particles of interest", it would be a bug if their values did not change. If you want a copy of their values, you can't be storing their pointers.
olesen is offline   Reply With Quote
dem, dynamiclist, lagrangian, momentum cloud, parcels
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 17:45
