level-set method_OpenFOAM
Old   March 7, 2022, 01:29
Default level-set method_OpenFOAM
Jongkwon Lee
leejk1120 is on a distinguished road
Hello.
I am looking for an OpenFOAM solver that uses only LS models to compare multiphase flow simulation of Volume of Fluids (VoF) and Level Set (LS) interface models. I could check the slsVOFFoam of S.Menon [2014], a CLSVoF model, but I could not find a solver that used only the LS model. Is there a multiphase flow solver that only uses LS model?
Thanks in advance
J. Lee
leejk1120 is offline   Reply With Quote
Old   July 13, 2022, 07:50
Michael Sukham
2538sukham is on a distinguished road
Haven't found only LS being implemented in openFOAM. Although we have coupled LSVoF. If you find, please do share as I too want to understand the implementation before diving into the coupled solver for interface tracking.
2538sukham is offline   Reply With Quote
Old   November 14, 2022, 15:19
Huan Zhang
Jasper Z is on a distinguished road
Dear Michael,
Can you please tell me which solver uses the CLSVOF? Thanks!
Jasper
Jasper Z is offline   Reply With Quote
Old   November 15, 2022, 00:46
Michael Sukham
Its Coupled Level Set VoF so its for multiphase simulations. InterFoam is the base solver.
Old   November 15, 2022, 00:51
Huan Zhang
Its Coupled Level Set VoF so its for multiphase simulations. InterFoam is the solver.
I don't think interFoam is the Coupled Level Set VoF. It just uses VOF, isn't it?
Old   November 16, 2022, 01:41
Michael Sukham
Level set is an interface capturing method. Coupled LS VoF actually takes advantage of the mass conservation of the VOF method and the sharp interface capturing of LS method. You can read the report by Sankar Menon "Coupled Level-Set with VOF interFoam".
Old   November 16, 2022, 01:45
Huan Zhang
But interFoam is not the Coupled Level Set VoF
Old   November 16, 2022, 04:11
Michael Sukham
Its for the curvature calculation and subsequently in the surface tension. Spurious currents resulting from the advection of the alpha also exist. Coupling improves the computation of curvature of the interface and its normal direction. But since its multiphase, the main solver will be based on interFoam and its family.
Old   November 16, 2022, 12:05
Huan Zhang
I agree with you, but the coupled level set needs to be implemented in interFoam as reported by Sankar Menon, because interFoam just uses VOF. In his report, the new solvers are termed sclsVOFFoam and sclsVOFFoamsf.
levelset, openfoam
Level set function in Fluent zx145833 FLUENT 1 October 9, 2024 01:34
How to set boundary conditions for cylinder+orifice mesh JD_PM OpenFOAM Running, Solving & CFD 0 March 1, 2022 06:02
[snappyHexMesh] Multiregion mesh - issues at edges namsivag OpenFOAM Meshing & Mesh Conversion 3 July 16, 2020 06:34
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
Set liquid level in a Tank chemeng OpenFOAM 4 April 7, 2010 00:46
