Variable thermal conductivity in chtMultiRegionSimpleFoam
Old   March 3, 2022, 00:35
Default Variable thermal conductivity in chtMultiRegionSimpleFoam
Sunag R A
sunagra27 is on a distinguished road
Hi all,
I am working with bio-heat transfer simulation using chtMultiRegionSimpleFoam solver.
I want to implement kappa (thermal conductivity) as a function of temperature.
I did not have any idea related to variable thermal conductivity. So, I watched this beautiful video where the thermal conductivity as a function is explained.
Video: https://youtu.be/ahI72iR_b6E
Now, I would like to implement kappa as a variable parameter such that as the temperature is solved, it should solve kappa also. As of now, the thermo-physical properties is as follows:
mixture
    specie
      molWeight   0;
    transport
        kappa   0.51;
    thermodynamics
        Hf      0;
        Cp      3770;
    equationOfState
        rho     1050;
Any leads towards a light on variable thermal conductivity in bioheat transfer equation will be appreciated.
Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
chtmultiregionsimpefoam, openfoam, temperature, thermal coductivity, variable conductivity
How to set Variable Thermal Conductivity? LThomes CFX 14 July 29, 2017 07:27
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 18:26
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
