How to add a source term which depends on position using codedSource
Old   February 9, 2022, 14:22
Default How to add a source term which depends on position using codedSource
manou mouna
Manouu is on a distinguished road
Hi Openfoamers, I published my problem on the forum a few days ago but I did not receive any help. I want to explain more my case, I am working on laminar flow in a cylindrical tube using simpleFoam solver. I use water as a fluid, in my experimental work, I applied an ultrasonic wave to the flow of the fluid in the tube, this wave will generate a volumetric force which will influence the speed of the flow. I calculated the values ​​of this force in each points of my mesh using a matlab code and I would now like to introduce only a value of this force in its point in openfoam as a constant source term in the z direction in order to study its effect on flow velocity. I am beginner on openfoam and I know that fvOptions allows me to add uniform source term which depends on position and according to UserGuide on codedSource I try to create the code below and use vectorCodedSource, the code it works but the solution doesn't converge and the results don't make sense, I reach huge speed values. how can I correct my code please? The force unit is m.s-2 (F/rho*Volume), I want to know how I can set the force unit in the code? I use openFoam 4.1
I hope to find help
regards
volumetricForce
type vectorCodedSource;
active on;
name volumetricForce;
vectorCodedSourceCoeffs
fields (U);
selectionMode points;
points
(0 0 0)
codeInclude
codeCorrect
Pout<< "**codeCorrect**" << endl;
codeAddSup
vectorField& USource = eqn.source();
const scalarField& V = mesh_.V();
vector const F (0,0,0.804);
USource -= F;
codeSetValue
Pout<< "**codeSetValue**" << endl;
code
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue
sourceTimeCoeffs
Last edited by Manouu; February 9, 2022 at 14:56. Reason: I want more detailed title
Manouu is offline   Reply With Quote
Old   June 25, 2022, 10:28
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
I hope to find help
regards
volumetricForce
active on;
fields (U);
points
(0 0 0)
codeInclude
codeCorrect
codeAddSup
USource -= F;
codeSetValue
code
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue
sourceTimeCoeffs
are you going to add the F values to all cells, like gravity, or just a specific cell?
Mahmoud Abbaszadeh is offline   Reply With Quote
Old   June 27, 2022, 05:42
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The soon-to-been-released OpenFOAM-v2206 will support volume expressions for source terms, which means that you should be able to shape the selection a bit more precisely.
Otherwise you will probably need to preselect cells as a cellSet and restrict your sources to them.
olesen is offline   Reply With Quote
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 10:32
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
