IOobject only retrieves field data at writeInterval
Old   February 1, 2022, 10:33
Default IOobject only retrieves field data at writeInterval
Carl Dahmen
carlDahmen is on a distinguished road
Hello Foamer!
I work with CFDEM but my question is purely OpenFOAM.
I have modified the Smagorinsky turbulence model to create a subgrid viscosity depending on the field voidfraction (Vgas/Vsolid). My problem is after the first timestep "0" I get the error message:
--> FOAM FATAL ERROR:
cannot find file "/home/carl/CFDEM/carl-PUBLIC-5.x/run/viscosityTest_BG/CFD/processorX/1.25e-06/voidfraction"
I believe this is because in this folder only the data at the writeInterval is saved. How do I retrieve the data at time 1.25e-6 and so on?
template<class BasicTurbulenceModel>
tmp<volScalarField> BatchelorGreen<BasicTurbulenceModel>::k
    const tmp<volScalarField>& voidfrac
) const
    volScalarField solidfrac(scalar(1)-voidfrac);
    volScalarField c1(a_*solidfrac+b_*sqr(solidfrac));
    return tmp<volScalarField>
        new volScalarField
            IOobject
                IOobject::groupName("k", this->U_.group()),
                this->runTime_.timeName(),
                this->mesh_
            c1
void BatchelorGreen<BasicTurbulenceModel>::correctNut()
    new volScalarField
    IOobject
        "voidfraction",
        this->mesh_,
        IOobject::MUST_READ_IF_MODIFIED
    this->mesh_
    volScalarField k(this->k(voidfraction_));
    this->nut_ = this->nu()*k;
    fv::options::New(this->mesh_).correct(this->nut_);
    BasicTurbulenceModel::correctNut();
carlDahmen is offline   Reply With Quote
cfdem, ioobject, runtime, smagorinsky, subgrid
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 21:06
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
External magnetic field data Richard Lee FLUENT 7 January 11, 2019 05:43
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 23:18
