Apply atmBoundaryLayerInletVelocity to varying terrain |
January 26, 2022, 14:08 |
Hongbin Wang
Rep Power: 6 |
I am modelling complex terrain with varying elevations. I want to apply atmBoundaryLayerInletVelocity (see https://cpp.openfoam.org/v3/a00073.html) to the inlet.
Please see below. zGround and Zref are defined with reference to the origin of z axis, which is applicable for a flat terrain situation. does anyone know how to apply atmBoundaryLayerInletVelocity terrain with varying elevations? inlet { type atmBoundaryLayerInletVelocity; Uref 10.0; Zref 500; zDir (0 0 1); flowDir (1 0 0); z0 uniform 0.1; zGround uniform 0.0; } |
February 1, 2022, 17:32 |
Tobias Holzmann
Rep Power: 51 |
Yes,
out of the box it is not possible. I might investigate here in future and patch the stuff for individual terrains (e.g., inlet is not flat). We had this question 2 weeks ago and there is a workaround. Specifying a prescribed velocity inlet
Keep foaming, Tobias Holzmann |
February 2, 2022, 08:33 |
Hongbin Wang
Rep Power: 6 |
Hi Tobi,
Many thanks. Much appreciated for your reply. I will have a look at the link you are referring. Cheers, Hongbin |
March 2, 2022, 18:07 |
migrate the code to codedFixedValue
Hongbin Wang
Rep Power: 6 |
Hi Tobi,
Sorry for responding to you this late as I have been very busy lately testing things. I am using turbineSiting case coming with OpenFoam 8 for testing purpose. The method you suggested as workaround worked. but the downside is that for running multiple processors (e.g. 8) I had to produce ununiform list for each processor for the inlet files. It is not practical for running large amount of modeling scenarios. Therefore, I am thinking about using codedFixedValue in inlet files applying equations in the link. https://cpp.openfoam.org/v3/a00073.html I managed to write a code below for U. the code works for flat terrain. the code basically, assign velocity (x direction) at cell centres at inlet patch. z direction is height. zg is assumed 0. The next step is to add a code to calculate the height of the cell centres from terrain elevation at the boundary line intersecting with the inlet. I wrote a code using foamNewApp setting up folders. The logic in the code is that i loop though mesh nodes on terrain patch and put those also on the inlet to a List. so for a cell centre with y, I can find the corresponding zg by interpolating the points in the list. a very linear two points interpolation is used. my c++ skill is very rusty now. not sure if there is c++ library which can achieve this easily. I attach the code. I need to migrate the code to the code below. the trouble is when i try to run simpleFoam. error pop up. mesh class is not recognised. any idea how to migrate the attached code into the code below? Many thanks, Hongbin inlet { type codedFixedValue; value $internalField; name codedInletBC; code #{ label id_ter = patch().boundaryMesh().findPatchID("terrain"); const polyPatch& ter = patch().boundaryMesh()[id].patch(); const fvPatch& patch = this->patch(); const vectorField& cf = patch.Cf(); scalar x=0, y=0, z=0, ustar=0.1, zg=0,k=0.41; const scalar z0=0.2, uref = 3.4, zref = 10; ustar = uref /log((zref+z0)/z0); vectorField& field = *this; forAll(cf, i){ x=cf[i].x(); y=cf[i].y(); z=cf[i].z(); field[i] =vector((ustar/k*log((z-zg+z0)/z0)),0,0); } #}; } |
March 3, 2022, 09:17 |
Hongbin Wang
Rep Power: 6 |
another thought to write a new boundary condition which inherit atmBoundaryLayer class. I need to rekindle my c++ knowledge. this is a pain for me right now.
https://cpp.openfoam.org/v3/a00073.html i found a note how to write a new BC> https://www.dam.brown.edu/people/ntrask/CFD/bctut.pdf |
March 4, 2022, 09:50 |
#7 | |
Tobias Holzmann
Rep Power: 51 |
unfortunately, I do have too much work at the moment to investigate into that particaluar problem. But it is on my todo list.
March 4, 2022, 17:39 |
Hongbin Wang
Rep Power: 6 |
Thanks Tobi for your response. Yes. the calculation is in the code snippet I provided. I tested with turbineSiting case. it worked, although i have to admit my c++ skills is quite basic. The code assumes x is the wind direction and y is the cross-wind direction and z is the direction of height. yes, it would be ideal to consider a generic coordinate system in a similar way as atmBoundaryLayer describes . Many thanks for putting this on your to-do list. I think this inlet wind condition for non-flat terrain would be very useful to many wind engineering situation involving real terrain.
March 7, 2022, 19:56 |
#9 |
Hongbin Wang
Rep Power: 6 |
Hi Tobi,
Just to let you know I have add some more lines in the snippet to calculated the difference in height of the centres at the inlet patch to its intersecting line with the terrain. I put centres with adjusted z being the difference in a list called pcfAdj. I have looked at atmBoundaryLayer class and atmBoundaryLayerInletVelocity class. the U profile is defined in atmBoundaryLayer functon atmBoundaryLayer::U (const vectorField& p) p in the function is patch cell centres (i think) U function is used in one of the constructor in atmBoundaryLayerInletVelocityFvPatchVectorField and refValue() = U(patch().Cf()); I guess it would might if patch().Cf() is replaced with the list of centres with adjusted z. anyway, just let you know i have updated the snippet. just ignore my message if you are busy. Cheers, Hongbin |
March 11, 2022, 05:17 |
#10 |
Hongbin Wang
Rep Power: 6 |
Hi Tobi,
I've finally got the approach to work after so much try and error although the code is very messy needing a lot of tidying up. Thanks for your attention anyway. Kind regards, Hongbin |
March 14, 2022, 04:46 |
#12 |
Hongbin Wang
Rep Power: 6 |
I am still wrapping up the code. Yes it works for all directions. as i mentioned before, regarding atmBoundaryLayerInletVelocityFvPatchVectorField, I only need to change refValue() = U(patch().Cf()) to something like refValue() = U(patchCentreRevised). no need to write code to handle directions. the same applies to epsilon and k.
How to apply variabe roughness, e.g. to complex terrain? | Fridolin | OpenFOAM Running, Solving & CFD | 3 | August 12, 2020 15:09 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Is my ABL simulation actually using my terrain file? | pajot | OpenFOAM Running, Solving & CFD | 1 | September 12, 2013 07:28 |
Which B.C. i should apply for this problem?urgent | raivish | Phoenics | 4 | February 16, 2006 04:35 |
which B.C. i should apply for this problem? | raivish | CFX | 0 | January 6, 2006 08:47 |
