Accessing species in coded function object
Old   January 23, 2022, 09:01
Default Accessing species in coded function object
Swirl is on a distinguished road
Hi everyone,
I am currently writing a coded function object for the reactingFoam solver. For the application I need to access the species. In the solver code this can be done by
forAll(Y, i){
doWhatever();
However, when using these expressions in the coded function object, I get an error saying that Y has not been defined. Can anyone help me figure out, how to access the species from a coded function object?
Thank you very much in advance!
Swirl is offline   Reply With Quote
Old   January 23, 2022, 13:08
Default Additional problem
There appeared another problem when creating an IOdictionary. For the Following code
IOdictionary reactions
     IOobject(
          "reactions",
          runTime.constant(),
          mesh,
          IOobject::MUST_READ,
          IOobject::NO_WRITE
I get an Error saying, that "runTime" was not defined in this scope. Please help me, I don't know much about coding.
Old   January 24, 2022, 04:52
Domenico Lahaye
dlahaye is on a distinguished road
Not sure.
Possibly looking into codedFunctionObject documented here https://www.openfoam.com/documentati...ionObject.html
Inside the codedFunctionObject you should be able to use forAll as intended.
Likely you will need to distinguish between fuel, oxidizer, product and inert species. This information is stored in the thermo.composition object
dlahaye is offline   Reply With Quote
coded functions, species
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 04:12
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
