Moving mesh simulation with mesh changes inside the solver |
Clemens Goessnitzer
Rep Power: 4 ![]() |
I currently run a moving mesh case with multiple meshes, i.e. I run simulation A from time 0 to time t_A, then I map the results from simulation A, t_A onto a new mesh, same geometry, but different number of cells, and run the simulation B from time t_A until t_B, then I again map onto a new mesh and so on:
Simulation A, mesh A runs from t_0 to t_A Simulation B, mesh B maps results Simulation A to mesh B (time t_A) runs from t_A to t_B Simulation C, mesh C . . . The reason for this procedure is that I have high deformations of my mesh, and I could not run the whole simulation using just one mesh. Does anybody know if there is a possibility of doing this mesh exchange inside a solver? I guess I would need a topology changer? Has anybody done such a project and could be so friendly and share his insight? Thanks! |
#2 | |
Jalvathi
Rep Power: 7 ![]() |
I think, you can use the mapFields option to map the results from one result/mesh to a different mesh. Please check the link here which shows how to map one results to a new mesh setup. I hope, this helps. Regards, Jalvathi |
Clemens Goessnitzer
Hi!
Thank you for your reply, but I already use mapFields in my workflow. However, this procedure takes a lot of time compared to the actual CFD solver part, so I thought that putting the mesh-to-mesh part inside the actual CFD solver would speed things up. Thanks. |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 7, 2021 23:17 |
Moving Mesh simulation | ccs1021 | OpenFOAM Running, Solving & CFD | 2 | January 18, 2021 09:50 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ANSYS Meshing] Meshing Strategy for inside geometry | powpow | ANSYS Meshing & Geometry | 6 | January 16, 2013 04:32 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
