January 10, 2022, 12:15 |
ref or free stream pressure in DSMC solver
Amirhossein Taran
Rep Power: 10 |
Dear foamers,
since I've been searching too long for this issue, I'm starting a new thread in this regard. the main question is " how we set the P in a DSMC case? " do we have any developed B.C library for this? I'm trying to simulate a case of supersonic flow with Ma=6, here I need to introduce the P in order to get the coefficient of pressure but there is a huge difference in the order of magnitude between the P in the paper and my results, P in the paper was set at 5 bar and the pressure which I obtained from the solution is about 1e-05 bar !!! please share your ideas if it's possible. Regards, Amir |
dsmc, dsmcfoam, pressure b.c |
How is the accuracy using VOF (pressure based solver) on supersonic flow | air_fun | Fluent Multiphase | 1 | August 25, 2021 01:59 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 02:47 |
