strain-rate dependent viscosity model, crashes on simulation
Old   December 1, 2021, 12:40
Default strain-rate dependent viscosity model, crashes on simulation
Michael W.
nightdust is on a distinguished road
Dear Foamers,
I am rather new to OpenFOAM (and C++) and set out to implement a new viscosity model: a piece-wise power law. Meaning that, depending on the strain rate, different power law parameters K, n will be chosen.
I have used the built-in power law as a starting point. I did some forum searches on the forum which informed my current code solution. At the moment, I still retained the original parameters k_ and n_ in my viscosity model, but later they will be supplanted by the scalarLists kList_ and nList_ .
I also created a small test case (square pipe), but if I try to run the simulation with my new own viscosity model, it crashes. (See attached pictures #1 and #2). I am able to use the original power law (that's why I retained the parameters k_ and n_) and print out my calculated values of nu, based on the local strain rate.
What makes me wonder is that the values of nu for the inlet, outlet an walls are still equal to the initial value I gave my volScalarField in the viscosity model. I understand that I only manipulated the values at the cell centres, and the values at the boundary (inlet, outlet, walls) are defined at the face centres. I thought that they were calculated based on the values of the cell centres.
Maybe there is a problem with a zero? I am not knowledgeable enough. But if I simulate the test case using the old power law calculation and print out my calculated new values, they seem to be calculated fine at every time step (see picture #3).
Since the error message is in German, I searched for its English equivalent. It should read: Segmentation error (core dumped).
What am I missing here? Thanks for your help!
My pieceWisePowerLaw.C file:
  \\      /  F ield         | foam-extend: Open Source CFD
   \\    /   O peration     | Version:     4.1
    \\  /    A nd           | Web:         http://www.foam-extend.org
     \\/     M anipulation  | For copyright notice see file Copyright
License
    This file is part of foam-extend.
    foam-extend is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by the
    Free Software Foundation, either version 3 of the License, or (at your
    option) any later version.
    foam-extend is distributed in the hope that it will be useful, but
    WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with foam-extend.  If not, see <http://www.gnu.org/licenses/>.
#include "pieceWisePowerLaw.H"
#include "addToRunTimeSelectionTable.H"
#include "surfaceFields.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
namespace viscosityModels
    defineTypeNameAndDebug(pieceWisePowerLaw, 0);
        viscosityModel,
        pieceWisePowerLaw,
        dictionary
// * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::pieceWisePowerLaw::calcNu() const
    // declare the scalars for K, n which will be used for the current cell
    scalar kToUse;
    scalar nToUse;
    volScalarField myNu
        IOobject
            "myNu",
            U_.time().timeName(),
            U_.db(),
            IOobject::NO_READ,
            IOobject::NO_WRITE,
            false
        U_.mesh(),
        dimensionedScalar
            "myNuInit",
            dimensionSet(0,2,-1,0,0,0,0),
            10.0
    // loop over all cells
    forAll(myNu, cellI)
        // use the K and n parameters of the last interval by default
        kToUse = kList_[kList_.size()-1];
        nToUse = nList_[nList_.size()-1];
        int j = 0;
        bool intervalFound = false;
        while(!intervalFound && j < kList_.size())
            // if the strain rate of the current cell centre is lower (or equal) than the kth threshold value,
            // choose K, n of the kth power law interval
            if(strainRate()()[cellI] <= gammaList_[j])
                kToUse = kList_[j];
                nToUse = nList_[j];
                // if the correct interval has been found, this variable will also cause the outer while loop
                //to terminate
                intervalFound = true;
            j++;
        // actual calculation of the viscosity (like power-law, but K, n are chosen based on the strain rate
        // of the current cell centre)
        myNu[cellI] = max
                nuMin_.value(),
                min
                    nuMax_.value(),
                    kToUse*pow
                        max
                            strainRate()()[cellI],
                            scalar(VSMALL)
                    nToUse - 1.0
    Info << "myNu: " << myNu << nl;
    //return myNu;
    // the original return (power law)
    return max
    nuMin_,
    min
        nuMax_,
        k_*pow
        max
            dimensionedScalar("one", dimTime, 1.0)*strainRate(),
            dimensionedScalar("VSMALL", dimless, VSMALL)
        n_.value() - scalar(1.0)
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::viscosityModels::pieceWisePowerLaw::pieceWisePowerLaw
    const word& name,
    const dictionary& viscosityProperties,
    const volVectorField& U,
    const surfaceScalarField& phi
    viscosityModel(name, viscosityProperties, U, phi),
    pieceWisePowerLawCoeffs_(viscosityProperties.subDict(typeName + "Coeffs")),
    k_(pieceWisePowerLawCoeffs_.lookup("k")),
    n_(pieceWisePowerLawCoeffs_.lookup("n")),
    nuMin_(pieceWisePowerLawCoeffs_.lookup("nuMin")),
    nuMax_(pieceWisePowerLawCoeffs_.lookup("nuMax")),
    gammaList_(pieceWisePowerLawCoeffs_.lookup("gammaList")),
    kList_(pieceWisePowerLawCoeffs_.lookup("kList")),
    nList_(pieceWisePowerLawCoeffs_.lookup("nList")),
    nu_
        IOobject
            name,
            U_.db(),
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        calcNu()
// * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * * //
bool Foam::viscosityModels::pieceWisePowerLaw::read
    viscosityModel::read(viscosityProperties);
    pieceWisePowerLawCoeffs_ = viscosityProperties.subDict(typeName + "Coeffs");
    pieceWisePowerLawCoeffs_.lookup("k") >> k_;
    pieceWisePowerLawCoeffs_.lookup("n") >> n_;
    pieceWisePowerLawCoeffs_.lookup("nuMin") >> nuMin_;
    pieceWisePowerLawCoeffs_.lookup("nuMax") >> nuMax_;
    pieceWisePowerLawCoeffs_.lookup("gammaList") >> gammaList_;
    pieceWisePowerLawCoeffs_.lookup("kList") >> kList_;
    pieceWisePowerLawCoeffs_.lookup("nList") >> nList_;
    return true;
My pieceWisePowerLaw.H file:
License
Class
Description
     Standard power-law non-Newtonian viscosity model.
SourceFiles
    pieceWisePowerLaw.C
#ifndef pieceWisePowerLaw_H
#define pieceWisePowerLaw_H
#include "viscosityModel.H"
#include "dimensionedScalar.H"
#include "volFields.H"
namespace Foam
                           Class pieceWisePowerLaw Declaration
class pieceWisePowerLaw
    public viscosityModel
    // Private data
        dictionary pieceWisePowerLawCoeffs_;
    // these two variables will later be removed
        dimensionedScalar k_;
        dimensionedScalar n_;
    dimensionedScalar nuMin_;
        dimensionedScalar nuMax_;
    scalarList gammaList_;
    scalarList kList_;
    scalarList nList_;
        volScalarField nu_;
    // Private Member Functions
        //- Calculate and return the laminar viscosity
        tmp<volScalarField> calcNu() const;
public:
    //- Runtime type information
    TypeName("pieceWisePowerLaw");
    // Constructors
        //- Construct from components
        pieceWisePowerLaw
            const word& name,
    // Destructor
        virtual ~pieceWisePowerLaw()
    // Member Functions
        //- Return the laminar viscosity
        virtual const volScalarField& nu() const
            return nu_;
        //- Correct the laminar viscosity
        virtual void correct()
            nu_ = calcNu();
        //- Read transportProperties dictionary
        virtual bool read(const dictionary& viscosityProperties);
} // End namespace viscosityModels
} // End namespace Foam
#endif
nightdust is offline   Reply With Quote
viscosity models
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
How to determine the mean filtered strain rate for the Smagorinsky model levinperson Main CFD Forum 5 November 30, 2015 14:00
Time and temperature dependent viscosity sur4j OpenFOAM 16 January 12, 2015 01:56
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 14:57
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
