October 29, 2021, 11:30 |
core dumped, please help me. :)
Dylan
Rep Power: 5 |
When running simpleFoam i am getting a floating point exception (core dummped message)
#0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #8 Foam::fvMatrix<double>::solve() in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #9 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" Floating point exception (core dumped) I cant figure out where i am going wrong. When running check mesh i also get one failure but cant figure out where it is. I have attached all the files i am using for the problem in the this mod_8 zip. and also attached the files i think are needed for use. i deleted the polymesh so blockMesh will need to be run. |
October 30, 2021, 10:21 |
Lorenzo
Rep Power: 6 |
From lines #3 and #5 it seems that the simulation stopped due to the GAMG solver. Try using smoother DICGaussSiedel instead of gaussSiedel for p in fvSolution. If it doesn't work, try with PCG solver instead of GAMG, and preconditioner DIC. Let me know if something changes. Regards, Lorenzo |
October 30, 2021, 12:30 |
Dylan
Rep Power: 5 |
Lorenzo,
I did as you said for both cases the first one did not solve either, only doing two time iterations. I will include the error message i receive here: (GAMG, DICGaussSiedel) #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #8 Foam::fvMatrix<double>::solve() in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #9 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" Floating point exception (core dumped) for the PCG and DIC it ran for about 5 time iterations and then stopped. below is the core cumped message: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #7 Foam::fvMatrix<double>::solve() in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #8 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam" Floating point exception (core dumped) |
core dumped, openfaom |
[OpenFOAM] Paraview segmentation fault core dumped | GLfast80 | ParaView | 0 | March 13, 2021 13:53 |
[foam-extend.org] core dumped for foam extended 3.2 on Ubuntu 16.04 | qjh888 | OpenFOAM Installation | 9 | September 27, 2016 17:39 |
Floating point exception (core dumped) in icoFsiFoam | viraj20feb | OpenFOAM | 2 | September 17, 2016 03:05 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 03:02 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
