Line term in the Navier - Stokes equation.
Old   October 21, 2021, 13:33
Default Line term in the Navier - Stokes equation.
Vladimir
vgoy is on a distinguished road
Hi!
I am new in fluid dynamics. In my scientific study required to introduce a linear term to the Navier Stokes equation. It means that on the right-hand side I have -\nabla p-\frac{1}{\tau} U, where \tau is constant. I found that OpenFOAM can solve this type of equation. I chose icoFoam solver for it and added line term in the next way:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
+ fvm::Sp(tauI, U)
Then I did some calculations, it seems to work. The only question left is, did I add the linear term correctly? Can I add it in another way to speed up the calculation? I have been looking for answers to my questions in the Internet for a long time, but for this I need to immerse myself in fluid dynamics with the right textbooks. Can you please tell me if I am on the right path? or a simple mistake?
Many thank for the help!
vgoy is offline   Reply With Quote
Old   October 26, 2021, 09:58
David GISEN
David* is on a distinguished road
The use of fvm::Sp seems correct to me, also the positive sign. But are you really sure that tauI is correct and not 1/tauI?
Regards,
David
Sources:
https://openfoamwiki.net/index.php/H...sport_equation
https://openfoamwiki.net/index.php/IcoFoam
David* is offline   Reply With Quote
Old   October 26, 2021, 10:07
Vladimir
Dear David,
thank you for your answer, this is important to me. Whenever you see an easy solution to your problem, it seems that there is a catch somewhere. For me, tauI is inverse tau, namely tauI=1/tau.
Best regards,
Vova.
line term, navier stoke solver, solver
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 17:16
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 30, 2015 00:42
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
