How can I access the updated coordinates on a rotating region from a functionObject
Old   October 17, 2021, 14:47
Default How can I access the updated coordinates on a rotating region from a functionObject
NotOverUnderated's Avatar
ONESP-RO
NotOverUnderated is on a distinguished road
I have tried both the coded function object, and implemented a custom function object using foamNewFunctionObject to print the coordinates of a cell on a rotating cellZone. When I invoke the function object, the Velocity is returned correctly and changes with time, however, the coordinates printed of the cell do not change with time, even though the cellZone is correctly rotating.
How can I solve that? in other words; how can I get the updated coordinates of cells in a rotating cellZone from within a functionObject?
I am stuck, and can't progress further without solving that issue.
Could you please provide me some insights?
(I am using OpenFOAM7)
Thank you
NotOverUnderated is offline   Reply With Quote
Old   October 18, 2021, 10:02
Bram Kerkhofs1
brammekeuh987 is on a distinguished road
Hi D.Frank
Could you post your code?
The simple answer is: you'll need to update the mesh or load the updated mesh. Most probably your reading the 'constant/polyMesh" over and over instead of the updated mesh
regards
brammekeuh987 is offline   Reply With Quote
Old   October 18, 2021, 18:45
s1291's Avatar
s1291 is on a distinguished road
Use writeCellCentres function object then use readFields Function object to read the centers as volVectorField.
s1291 is offline   Reply With Quote
Old   October 18, 2021, 18:49
ONESP-RO
Here is a minimal example:
type coded;
libs ("libutilityFunctionObjects.so");
name printMovingCoordinates;
codeWrite
	// The velocity field
	const volVectorField& U = mesh().lookupObject<volVectorField>("U");
	// the id of myZone
	label zoneId = mesh().cellZones().findIndex("myZone");
	label cell_id = -1;
	if (zoneId != -1)
		const cellZone& zone = mesh().cellZones()[zoneId];
		const cellZoneMesh& zoneMesh = zone.zoneMesh();
		const labelList& cellsZone = zoneMesh[zoneId];
		forAll(cellsZone, i)
			cell_id = cellsZone[i];
			Info << "The velocity is changing " << U[cell_id] << endl;
			Info << "But the cells are not changing over time: " C[cell_id] << endl;
Old   October 19, 2021, 03:48
Bram Kerkhofs1
Hi D.Frank
The code is correct: your cell_id isn't changing, and it shouldn't change. These ID's are the reference towards your cells. As per your code: your cell_id is a 'label' not a 'vector'. So your code is correct, but you're missing the link between the cell_id and the calculation of the cell centre.
You can do as s1291 suggests, or manipulate the source code of the writeCellCenters function into your custom function.
Or depending on what you're doing this thread could also help: functionObject to retrieve position writes correct to "Info<<" but wrongly to file
Hope this helps!
openfoam
FloEFD rotating region 310toumad FloEFD, FloWorks & FloTHERM 4 September 11, 2019 10:28
Access (x y z) coordinates of cellSet hxaxtma OpenFOAM Programming & Development 1 January 21, 2016 06:40
Rotating region of a centr. pump - Counter R wall Emre CFX 0 September 20, 2007 10:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
