Errors in compiling DOM/DORT (no matching function for call error) |
October 5, 2021, 02:38 |
Bushra Rasheed
Rep Power: 5 |
Hi!
Has anyone been able to compile this solver and radiation model? https://gitlab.com/Jose_Moreno/openfoam_dom This was made to be run on openfoam7. I tried it on openfoam7 using ubuntu 18.04 but it gave me error: radiationModel/DORT/discreteOrdinate/cleanDO/cleanDO.C:92:9: error: no matching function for call to ‘solve(Foam::fvScalarMatrix&, const char [3])’ I have tried compiling on openfoam v2106 as well but no luck. Please help! Thanks! Edit: I was able to compile it on openfoam v7.0. The error was because of two openfoam versions placed in the same directory where .bashrc file was present (in which openfoam is sourced during installation). The compilation was looking for solve function in other openfoam version directory instead of openfoam v7. Removing the other openfoam version worked and the solver compiled successfully. Last edited by B_R_Khan; October 26, 2021 at 05:25. |
compilation error, dom model, radiation fvdom |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 14:46 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 19:11 |
issue compiling new turbulence model | perplexed user | OpenFOAM Programming & Development | 1 | January 13, 2012 04:40 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
