U is different from fvc::reconstruct(phi)
Old   September 7, 2021, 06:02
Default U is different from fvc::reconstruct(phi)
H. Xia
H.Xia is on a distinguished road
Hi all,
I am working on basic coding with interFoam solver, and I try to compare the difference between two velocity fields:
1. U is the one-field velocity solved from the governing equations
2. Un is reconstructed from phi, which is the flux.
Un = fvc::reconstruct(phi)
Normally, the two fields should be the same (right? if not, please correct me), however, in my simulations, I found that U is a little bit large than Un, and you can find the attached figures which can help you to understand my question.
I hope you can give me some suggestions on this problem.
Many thanks,
H. Xia
H.Xia is offline   Reply With Quote
Old   September 8, 2021, 07:49
Michael Alletto
mAlletto will become famous soon enough
It's not the same. fvc:reconstruct is made to smooth out oscillations and therefore it smoothed out also steep gradients. Some detailes can be found in https://www.researchgate.net/publica...reconstruction and references therein.
Of course the source code helps and maybe some googling
Best
Michael
mAlletto is offline   Reply With Quote
Old   September 16, 2021, 05:37
H. Xia
Hi Michael,
Thank you very much,
H.Xia
fvc::reconstruct(), interfoam, vof
simpleFoam/potentialFoam crash during fvc::reconstruct(phi); bennn OpenFOAM Running, Solving & CFD 4 November 16, 2016 08:11
