August 5, 2021, 00:49 |
Calculation of Inviscid Jacobian in HiSA
ugurtan
Rep Power: 6 |
Hello Foamers,
I have just started to use OpenFOAM Solver HiSA (High Speed Aero) Solver and I try to understand the structure. I am using AUSMPLUSUP flux scheme with Lax Friedrich inviscid Jacobian scheme. The flux is calculated using as declared in Liou's journal in 2006 to assign the values of Phi, PhiUp, PhiEp and Up while the inviscid Jacobian is used by assigning different sections on this jacobian with the tools of div and grad. However, I missed the point where the calculated fluxes are used in the addition of Inviscid Jacobian. Because it appears to me that volscalarfields and volvectorfields are used by the operators of div and grad. It would be quite beneficial if someone can explain where the calculated fluxes at the surfaces are used as an input for the calculation of inviscid Jacobian. |
May 3, 2022, 10:10 |
Madong
Rep Power: 5 |
Hello,ugurtan666
I study hisa recently, and I try to understand the structure.But I can not understand the project,could you give some information of this solver? Thanks |
May 17, 2022, 07:59 |
Saleh Abuhanieh
Rep Power: 9 |
For inviscid Jacobian, HiSA uses first-Order (Lax Friedrich) scheme. This is why it doesn't use the fluxes calculated for the RHS like AUSM or HLLC. Instead, it uses the analytical derivative of the normal fluxes vector. This is common for the codes that use the defect-correct method for the approximate Newton solvers; first-Order for LHS and second-Order for RHS. The codes which use the finite difference method for the inviscid Jacobian calculation (e.g. SU2) need the calculated fluxes values. Many useful information are available at their gitlab page. https://hisa.gitlab.io/doc.html I hope that was useful. Regards, Saleh |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 10:37 |
Propeller calculation | toil | CFX | 15 | May 22, 2017 05:06 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 04:07 |
Quick Question on Calculation Time | Davitt | COMSOL | 0 | January 14, 2016 15:16 |
Inviscid Flux Calculation | mecbe2002 | OpenFOAM | 1 | April 8, 2010 02:52 |
